Go to Post When it is so boring and slow on here in the summer it is funny how all of us just jump at something technical. - sanddrag [more]
Unread 13-01-2016, 15:57
Re: 6 wheel drop center Question
Originally Posted by Kevin Leonard View Post
I have no idea how your drivetrain could have torn itself apart.
Originally Posted by CryptoStorm View Post
How exactly did it tear itself apart?
Do tell, please.
Unread 13-01-2016, 18:43
LoneWo1f1998's Avatar
LoneWo1f1998 LoneWo1f1998 is offline
FRC #4859 (Cybears)
Team Role: CAD
LoneWo1f1998 is an unknown quantity at this point
Again, I wasn't on the team that year so all I know is that chains were popping and the robot could barely turn even though it had been fine while testing on less grippy carpet. It apparently lurched a lot and they never quite fixed it, but were able to decrease the problem by making the wheels less grippy. As far as wheels go, we are considering 8 inch pneumatic or really anything that is 8 inch and grippy. What I really want to know is how much farther down to place the center wheel as compared to the others. This is like the fifth time I've designed a drivetrain, but we simply haven't needed the 6 wheel drop center in the past.
Unread 13-01-2016, 19:08
Thank you. That's much more informative.
Chains popping sounds like perhaps they were not tensioned properly, or not enough teeth engaged, or chain size too small.
Not turning on more grippy carpet sounds like not enough center drop.
Unread 14-01-2016, 08:21
FRC #4859 (Cybears)
Team Role: CAD
Thanks for helping me zero in on what went wrong that season. I'll try to look back and avoid those mistakes, but how low do you think the center wheel should be?
Unread 14-01-2016, 08:26
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The most common "drop" in the center wheel is 1/8". With pneumatic wheels, you may want to increase that slightly, due to the deformation of the tires under weight. Hard to say exactly, given that it could change with your tire pressure and weight distribution. I find it highly unlikely you'd need to go beyond 1/4", however.
With regards to chain, also make sure the sprockets are aligned properly.
Unread 14-01-2016, 08:49
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Andy Baker (Andymark) has a great power point on basic drive trains. There are many others presentations. Google is your friend, One of the big advantages of 6 wheel systems over 4 wheels tank drive is that the shorter effective wheel base makes it easier to turn. That is assuming that it is set so the robot is mostly supported by the center and one one set of the outboard wheels. Pneumatic wheels are going to make proper set up more critical. Any tank drive has to scrub the wheels to turn. High grip wheels are going to need a lot torque to turn from a stand still and the turn is likely to be a little jumpy. This is one reason many teams use omni wheels on the corners.
