Go to Post And when the President of the United States is playing with LEGOs and getting down on the floor to look inside of robots, then I would have to say "Mission Accomplished". - OZ_341 [more]
Unread 13-01-2016, 15:16
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
Re: Scaling via jack up legs instead of "hanging"?
Originally Posted by m1tche11d View Post
Do you know the team numbers of any of these teams, so I can find the archived match videos?
Thanks
I know our team built one, but I don't think we ever used it outside of practice matches because the rest of our climbing system was just completely broken. It wasn't an original idea, but I can't think of any offhand, and the few teams I did search didn't turn up any interesting videos.
I did check the 2013 manual though, and there aren't any special exceptions to the bumper rules related to climbing or anything.
the rule in question is almost completely identical:
Originally Posted by Ultimate Ascent R25
BUMPERS must be located entirely within the BUMPER ZONE, which is between 2 and 10 in. from the floor, in
reference to the ROBOT standing normally on a flat floor.
Proud alum of CORE 2062.
www.core2062.com
Unread 13-01-2016, 15:45
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The Team update (3.4.5 G19-1 & 4.7-R22 blue box) makes it pretty clear that it is not legal for 2016.
My interpretation of the 2013 rules is that it wasn't legal then, but then I was neither your robot inspector or your referee. The climbing rule was your robot could not be in contact with the floor & get credit so the bumper interpretation was less of an issue.
Unread 13-01-2016, 15:46
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Today's team update makes it pretty clear that jack up legs are not legal.
This topic is getting covered pretty thoroughly on the team update thread.
Additions include:
G19-1
ROBOTS must be in compliance with
Section 4.7: BUMPER Rules
throughout the MATCH.
Violation: DISABLED
R22 Blue box added.
This measurement is intended to be made as if the ROBOT is resting
on a flat floor (without changing the ROBOT configuration), not relative
to the height of the ROBOT from the FIELD carpet.
Examples include:
A.
A ROBOT that is at an angle while traversing a DEFENSE has its
BUMPERS outside the BUMPER ZONE. If this ROBOT were virtually
transposed onto a flat floor, and its BUMPERS are in the BUMPER
ZONE, it meets the requirements of R22.
B.
A ROBOT deploys a MECHANISM which lifts the BUMPERS outside
the BUMPER ZONE (when virtually transposed onto a flat floor). This
violates R22.
The second part of the R22 blue box seems to be a direct ruling on jack up scaling.
Re-Edit. Dagnabit. Sniped.
Edit: 100th post; woohoo. Only took me 5 years.
Alan Gilgenbach
C.O.R.E 2062
Unread 13-01-2016, 16:03
nightpool's Avatar
robotRectifier
AKA: Evan
Yep today's team update certainly clears this up. I feel like this is to the detriment of a lot of the more unusual/interesting strategies for navigating defenses (I expected them just to update the way a scale was scored) but at least its unambiguous now.
www.core2062.com
Unread 13-01-2016, 16:25
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
And a little less unsafe given the sloped & slick nature of the existing Tower Batter design, as the robot on uneven jacking legs on that particular slope & material at least before reaching the full required height and grabbing the bar (if that was at least intended), would be quite precarious in relation 2 other scaling or surrounding robots. (Not that they also aren't if one is using the usual extend, grab, winch, hang method, amongst others).
Here is to just hoping that latching, grabbing, hooking systems used to grab the unique Bar & Scale the Towers are accurate, robust, automatic, and safe. (Manual unhooking allowance of said latches usually are recommended, as all robots are then disabled at completion of the matches and will not be powered up to effect any unhooking operation by the Robot Drive Team(s). Members).
