Go to Post Its not how much knowledge you have, its how much you want to learn. - tennispro9911 [more]
Unread 13-01-2016, 14:12
VaneRaklan VaneRaklan is offline
FRC #2557 (The SOTABots)
VaneRaklan is an unknown quantity at this point
Porting Talon SRX
So we are trying to program using CAN but for some reason everything that I try says that the CAN Talon is a null pointer. Is there a specific way of writing the ports for the CAN Talons?
(I would add my code to this post, but I forgot how to do that)
Unread 13-01-2016, 14:51
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: Porting Talon SRX
It sounds like your creating the CANTalon variable, but not calling the new operator.
Take a look at section 3.2.3 in the Talon SRX Software Reference Manual. See the line that reads...
CANTalon customMotorDescript = new CANTalon(0);
It sounds like you are just doing
CANTalon customMotorDescript;
The number you pass into new CANTalon(x), is the device ID of the Talon. Use the web-based config to set the IDs of the Talons so that each one is unique (See section 2 in the Talon software reference manual).
Unread 13-01-2016, 15:02
ozrien's Avatar
Omar Zrien
AKA: Omar
Link to get the Talon SRX Software reference manual...
http://www.ctr-electronics.com/contr...ical_resources
Unread 13-01-2016, 15:35
Like I said, If I knew how to add my code to a reply you could see what I am doing. I did, in fact, write it just like that. (CANTalon motorDescirption = new CANTalon(x)
Unread 13-01-2016, 15:52
Is there some reason why you can't just cut and paste the relevant portion(s)?
Unread 13-01-2016, 16:09
ozrien's Avatar
Omar Zrien
AKA: Omar
Well ok....but I have no way of knowing how you wrote it...
Ether is right, just copy/paste the important part. Or zip it up and email to support@crosstheroadelectronics.com, and I'll bounce it back to this thread.
Unread 13-01-2016, 16:33
public class RobotMap {
public static SpeedController frontLeft;
public static CANTalon frontRight;
public static CANTalon backLeft;
public static CANTalon backRight;
public static RobotDrive robotDrive;
public static void init(){
frontLeft = new CANTalon(3, 0);
// frontRight = new CANTalon(4);
// backLeft = new CANTalon(1);
// backRight = new CANTalon(0);
robotDrive = new RobotDrive(frontLeft, frontRight, backLeft, backRight);
robotDrive.setSafetyEnabled(false);
Unread 13-01-2016, 16:42
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The frontRight, backLeft, and backRight pointers are null because those constructor lines are commented out. This would likely cause a null pointer exception in the robotDrive constructor. Also, if you wrap your code in code tags (highlight the block and click the # symbol), it's easier to read.
Unread 13-01-2016, 16:44
I realize that they are commented out. Currently I am only calling on the single motor and it still says that it is a NullPointer
Unread 13-01-2016, 16:46
ozrien's Avatar
Omar Zrien
AKA: Omar
Yep GeeTwo is right. frontRight is being created but you are not assigning it to a new'd object instance, so it stays null.
Remember frontRight is just a reference. In java you must assign to the return of a new operator to actually create the relevent object. If you put a breakpoint just before the NullException occurs and add frontRight to your watch list, you'll see it's null.
Unread 13-01-2016, 16:47
ozrien's Avatar
Omar Zrien
AKA: Omar
Yeah but robotDrive is still created and used, which uses all four underneath.
Unread 13-01-2016, 16:49
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The null pointer exception is probably being thrown by the new RobotDrive() constructor, which has three null pointers. If you just want to test one motor, use a manipulator sample code rather than drive code.
