Go to Post It moves so smoothly because it is magic. - dtengineering [more]
Unread 13-01-2016, 16:41
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Linking a line in a sketch to a plane
How do you link a line in a sketch to a plane in inventor 2016? The desired outcome would be that if I move the plane the line moves inside the sketch. And if a solid is extruded that uses that line the solid also updates.
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 13-01-2016, 16:53
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Linking a line in a sketch to a plane
I'm not totally clear on what you are trying to do, but it sounds like you need to project the geometry of the plane into your sketch, then make your line coincident with the projected line.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 13-01-2016, 17:11
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
Hey Jeffrey.
Lets say I define put a rectangle on a sketch. I then want to link one side of that rectangle to a plane that is in my part. Lastly, I want to be able to change the location of the plane and have the line move in the sketch.
In the image i attached i want ti link line 2 to plane 2. i then want to move plane 2 and have line 2 move with it.
Name:	link line plane sketch.jpg
crazy engineer
helping team 1389
Unread 13-01-2016, 17:13
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
In my current session, the projected line that i create in sketch based on the plane does not move when i move the plane.
crazy engineer
helping team 1389
Unread 13-01-2016, 17:24
FRC #6357
Alright. Still sounds like projected geometry with a coincident line. Are you sure you projected the line, then drew the line and made it coincident? If you don't choose to project the geometry, then that line won't track as you move the plane.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 13-01-2016, 17:26
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
try putting in a dimension and enter "0" for the dimension.
Unread 13-01-2016, 19:08
Spirator Spirator is offline
AKA: Munaum Muhammad
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Even with projected geometry and an adaptive sketch, the projected line will not move with the plane.
You may want to look into defining a variable for the plane distance and then defining your rectangle dimensions with the same variable.
To do this, you can type "planeDist = 100" in the dimension box when defining your plane distance from the origin. Then when you are defining the rectangle dimension, use the same variable.
Let me know if you have any questions.
Unread 13-01-2016, 20:51
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
I have attached a test assembly and detail as an example. If you change the work plane1,2,3 or 4 the solid does not update. But if you change work plane 5 it does. How can I get it to change when ever I change any of the planes.
crazy engineer
helping team 1389
Unread 13-01-2016, 21:04
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
I think I may have figured it out. Looks like I need to bring all of the planes in to every model.
Thanks for the help.
I am used to parametric design just working in catia. Looks like it is a lot more work to do in autodesk.
crazy engineer
helping team 1389
