Go to Post On a team, saying "it's not my job" is simply not acceptable. - dlavery [more]
Unread 13-01-2016, 18:21
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Router Resolving mDNS with nonsensical addressses
Hello! So I've been unpacking our teams KoP and setting up a freshly updated board and playing with the router. In some tests, I've noticed something peculiar about the router and how it resolves mDNS. The first time you request an address from it, it will return an IPv6 address that doesn't exist. The second time and subsequent times within an instanenous time frame will return an ipv4 address that is valid. For a visualization, see the command log
C:\Users\illid_000>ping roborio-1684-frc.local
Pinging roborio-1684-frc.local [fe80::280:2fff:fe17:6109%11] with 32 bytes of data:
Destination host unreachable.
Ping statistics for fe80::280:2fff:fe17:6109%11:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
Pinging roborio-1684-frc.local [10.16.84.59] with 32 bytes of data:
Reply from 10.16.84.59: bytes=32 time=1ms TTL=63
Reply from 10.16.84.59: bytes=32 time<1ms TTL=63
Ping statistics for 10.16.84.59:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\Users\illid_000>
I don't believe this to be computer side because I've tested with two different computers, NI MDNS on both and Bonjour on one and recieved the same results on every test.
Is anyone else experiencing this issue?
