What should C++ Include and Lib Settings Be for building Robot code?
Hello,
After following the instructions in screen steps (multiple times) and encountering no errors during the setup I am running into errors related to not having include (and possible) lib environment settings set up correctly. I have generated a sample project and am getting errors complaining that Symbols that can't be resolved. These symbols included WPILIB symbols, symbols in my own code, and C++ std runtime symbols. I fixed the WPILIB symbols by defining a WPILIB environment variable in the C/C++ Build -> Environment dialog for my project. However I am still left with C++ std:: symbols and some symbols in my project (like CommandBase when looking and ExampleCommand.h). These errors are concerning because I think the screen step setup should ensure these are already defined. Can someone please share with me the entire set of Environment variables needed for compiling and linking so I can ensure that everything is correct? I have attached a screen shot of the errors for reference Thanks, Rob Saccone Software Mentor Team 3950 Last edited by rsaccone : 01-13-2016 at 06:46 PM. Reason: Add attachment |
Re: What should C++ Include and Lib Settings Be for building Robot code?
OK I tried to add a picture but for some reason it won't upload. The unresolved symbols are around things like:
#include <string> - Can't find include std::unique_ptr std::string etc... |
If c++ standard library symbols can't be resolved (especially NULL) it's probably because your C++ index needs to be rebuilt. Right click the project > index > rebuild.
Otherwise check your include paths and make sure you have the include directory from the FRC c++ toolchain (somewhere in C:\frc on Windows) |
