Go to Post I've determined that the only thing rumors are good for is putting your knickers in a twist. - JaneYoung [more]
Unread 13-01-2016, 18:46
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Router Resolving mDNS with nonsensical addressses
It's a possibility... we're testing right now but I'll reflash the router when we get back to building and see if that resolves anything
Unread 13-01-2016, 18:50
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
The utility installed with the FRC update kit only works with router's that come preinstalled with the KOP system I believe. We followed the directions that came on the box for our router, see here.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 14-01-2016, 01:41
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Lightbulb Re: Router Resolving mDNS with nonsensical addressses
IPv6 fe80::/64 are link local addresses.
In IPv4 169.254.0.0/16 are the link local addresses
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
