Go to Post The culture has shifted, people. You can act shocked and complain, and likely lose the attention of the students you want to reach through FRC and other activities, or you can shift with it, and make FRC relatable and relevant to a bunch of good kids with foul mouths. - mrnoble [more]
Unread 13-01-2016, 19:22
TomBuchler TomBuchler is offline
FRC #0070
TomBuchler is an unknown quantity at this point
Re: Defenses and Breaching
Originally Posted by BrianAtlanta View Post
Let me try to explain with examples.
1. get through a defense and be totally in the courtyard. Score 10pts for crossing, defense takes a point of damage.
2. Get through a defense in to the courtyard (defense takes 1pt of damage), turn around drive over a defense in to the neutral zone. Turn around, drive over the defense and in to the courtyard a second time (defense does not take any damage and you get no points). 10pts
Brian
BRIAN,
Just so I understand this correctly. I understand if you start in the neutral zone, go through the defense, and into the courtyard that will count as 1 "breach". Now let's say you start at the courtyard, go through the "same defense", and into the neutral zone. Will that count as a "breach" also?... IE (2 breaches) Or must you ALWAYS start in the neutral zone and go towards the courtyard for it to count as a "breach'?
Unread 13-01-2016, 19:33
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by TomBuchler View Post
BRIAN,
A CROSS is only in one direction. From the Glossary:
CROSS an act performed by a ROBOT, such that it starts free of contact with an opponent DEFENSE and completely in the NEUTRAL ZONE, traverses the DEFENSE such that its BUMPERS go fully between the adjacent SHIELDS/GUARDRAIL, and ends up fully contained by the opponent’s COURTYARD
You must go from NEUTRAL ZONE to COURTYARD for it to count as a CROSS.
If you go back from the COURTYARD to the NEUTRAL ZONE you are traversing the DEFENSE and thus are protected from interference per G43. But you get no points for it.
(since 2004)
