Go to Post Karthik is afraid of the day he can't agasabapathy. - DesignComp [more]
Unread 12-01-2016, 08:30
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
Re: We are going to Want a GRIP fourm
Agreed, there needs to be a forum
Unread 12-01-2016, 16:49
Ti-Gars's Avatar
Ti-Gars Ti-Gars is offline
Wizzard
FRC #3360 (Hyperion)
Ti-Gars is on a distinguished road
Originally Posted by nightpool View Post
Can you read other types of NetworkTable values, such as from the Smart Dashboard or ones inserted manually in the NetworkTable Viewer? Sounds like your robot code isn't connecting to the same network/NT instance that your laptop is on.
I am connected to my robot while running my code. When my robot boot, I see in my Riolog :
NT: server: client CONNECTED: 10.33.60.25 port 56974
But I am not able to get my values. I am using this line of code to get them :
table = NetworkTable.getTable("/GRIP/myContoursReport");
double[] defaultValue = new double[0];
double[] areas = table.getNumberArray("area", defaultValue);
I also tried to see if he find my "key", but it doesn't see it.
System.out.println(table.containsKey("area");
We are guessing that our problem is that our robot is not able to connect to our Network Table who's on our laptop. Still, we don't know how to do it.
Unread 12-01-2016, 21:20
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Can you post a screenshot of your GRIP pipeline?
Unread 13-01-2016, 13:45
Ti-Gars's Avatar
Wizzard
This is my pipeline
And this is what I am able to see in Network Table Viewer
It seems like we now need to use NetworkTables 3.0 (Source) I am presently importing :
import edu.wpi.first.wpilibj.networktables.Networktable;
And I don't know how to import the new ntcore library.
Unread 13-01-2016, 18:40
shlynfrhm shlynfrhm is offline
FRC #3039 (Wildcat Robotics)
shlynfrhm is an unknown quantity at this point
Hey, I'm also having problems accessing the data from my NetworkTables. This is my code, and I've also imported NetworkTables before my program. I'm not able to see live publishing from GRIP to the Network Tables, has anyone been able to successfully do this and could give me an example? I followed the instructions on WPILib, but I feel as if I'm missing some code. Also, we program in command-based and I'm not sure where to implement this code in that format.
public class Robot extends SampleRobot {
    final String defaultAuto = "Default";
    final String customAuto = "My Auto";
    String autoSelected;
    SendableChooser chooser;
    NetworkTable table;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public Robot() {
    public void robotInit() {
        chooser = new SendableChooser();
        chooser.addDefault("Default Auto", defaultAuto);
        chooser.addObject("My Auto", customAuto);
        SmartDashboard.putData("Auto choices", chooser);
        while(true){
        	double[]areas=table.getNumberArray("area", defaultValue);
        	System.out.print("areas:");
        	for(double area:areas){
        		System.out.print(area + " ");
        	System.out.println();
        	Timer.delay(1);
Thanks!
Ashlyn
Unread 13-01-2016, 20:12
FRC #0237
Originally Posted by shlynfrhm View Post
Not sure if this will make a difference, but maybe try using "GRIP/myContoursReport" as the table name instead of "/GRIP/myContoursReport".
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 13-01-2016, 20:26
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Originally Posted by jojoguy10 View Post
Their Wiki on GitHub is also very useful. Here is the section on running the algorithm on the RoboRIO: https://github.com/WPIRoboticsProjec...an-FRC-program
That link is no help currently.
Unread 13-01-2016, 20:56
I changed it and it had no effect. Does anyone know of teams with code releases who have successfully implemented GRIP?
Unread 13-01-2016, 21:19
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
That will be a tough thing to find right now as GRIP is new for this season. I am unaware of any public code releases using it at the moment.
Unread 13-01-2016, 22:50
Juxttech Juxttech is offline
FRC #4918
Juxttech is an unknown quantity at this point
Hey everyone, we're trying to get our GRIP deployed to the roboRIO (using its ip address 172.22.11.2 and our team number 4918) but every time we try to deploy it, GRIP says "failed to connect". Any reason why it might be doing this?
Unread 14-01-2016, 00:32
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
I just tried your exact code using "GRIP/myContoursReport" (with no leading "/") and it works for me. When run with a leading "/" it doesn't work, because NetworkTable.getTable() unconditionally prepends "/" to the name you provide it.
As a side note, you really should put the operational part of your code into robotMain() instead of robotInit(), because FRCNetworkCommunication isn't getting initialized this way (you'll note it's not possible to enable your robot and the driver station says "no robot code" because you're never exiting robotInit).
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 14-01-2016, 00:36
Rookie Year: 2015
I got something to not fail by using the roboRIO.####-FRC.local in the advanced tab of deploy for an address. I then added the line
Runtime.getRuntime().exec(new String[]{"/usr/local/frc/JRE/bin/java", "-jar", "grip.jar", filename});
To my robotinit both with and without starting the image streaming but with no luck. Nothing posting to the network tables from the roborio. The code did post to the network table when grip running on my pc.
One of these days someone's going to crack this and get it working I hope they share with the rest of us. I would still like to find out how to:
1: deploy to the rio
2: use the driver station to process the usb cam
I do see my cam name is "cam1" but in grip its cam0 when plugged into the pc. All my searching on how to force the roborio cam name to cam0 resulted in just use the name it was assigned.
Last edited by cpapplefamily : 14-01-2016 at 00:44. Reason: type on a crapple I men Apple I pad
Unread 14-01-2016, 00:40
Rookie Year: 2015
I also browsed the roborio for mygripprogram.grip on the rio using sftp utility as discussed on how to add files to the robot but don't know where to look.
Unread 14-01-2016, 09:53
jmguillemette jmguillemette is offline
FRC #4525
jmguillemette is an unknown quantity at this point
Hi Everyone,
My team has succeeded at making a GRIP vision script, loading it to the RIO and getting the values out of the network tables.
the only thing that i now want to do is be able to controll the launching and stopping of grip from my code (instead of using the GRIP UI application)
some things we tripped on getting this this point:
-The Grip deploy process
---when you deploy make sure your settings are your robot's address
---after you deploy there is a delay (about a min) then a NEW button appears just above the deploy log window (it looks like the "play" triangle) Push this button to run the GRIP process in headless mode on the rio..
No data will be published to the network tables till you do this step.
NetworkTables
---Despite the fact i told my last step in the GRIP script to publish to "Vision" which would translate to "GRIP/Vision" in networkTables .. it didnt use my value.. instead only the default value provided by the step appears to work.
in out case this was a contours publish so its "GRIP/myContoursReport"
Another Note:
GRIP will have dedicated control of the camera.. Any attempts to stream the camera after grip has started will failed with an "in use" error. If your already streaming its likely grip wont be able to access the camera and will silently fail.
If any team is looking as to how to use GRIP to do targeting i would be happy to provide a plain english write up on how we are approaching this problem and how you can use grip to solve it.
Unread 14-01-2016, 10:13
Rookie Year: 2015
Originally Posted by jmguillemette View Post
Hi Everyone,
NetworkTables
Another Note:
Can you clear up a few steps leading up to this.
1. When developing the Grip script where is the camera connected? PC/Rio USB/IP Web cam
2. On the PC what is the Camera Name? Cam0.1.2....
3. If USB what is the USB camera name when viewing the WebDashboard?
4. What is the Deploy address you are useing?
I have never waited for the PC deploy and didn't know I would have an option to start the script on the Robot from the PC. I'll check that out.
As for starting the GRIP Wiki say to add this to start the app with the robot.
For stopping I don't have an answer but I can see a need.
JAVA:
Can we not stream and us Grip at the same time?
Last edited by cpapplefamily : 14-01-2016 at 10:18. Reason: Added the Java Tag for start code
