Go to Post 30 point hang is brutal. Those who say it is easy are not thinking it through or are way smarter than the rest of us ... - Paul Copioli [more]
Unread 13-01-2016, 20:41
FRCteam5837 FRCteam5837 is offline
FRC #5837
FRCteam5837 is an unknown quantity at this point
JAVA RobotDrive Motors Signal Out of Sync
During programming of our test stand in JAVA, we found that regardless of control channel for the move speed value, the motors start rotating at different points. This will cause a robot to turn at low speeds with no turning inputs.
This issue was confirmed with multiple channel changes of the motors, and the problem switching motors if the channel for motor signal is switched.
Is there an inherent problem in the RobotDrive or other library files that may be causing this problem?
We are using the arcadeDrive function to feed outputs to the robot.
Regardless of the changes made to the control scheme the problem persists. Resolution of this issue appears to require a PID controller to ensure constant direction without turning input. While this would be one way to solve a built in turn, this should not be required to make an aligned robot move straight forward.
Anyone with information on this issue would be much appreciated.
Unread 13-01-2016, 20:55
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: JAVA RobotDrive Motors Signal Out of Sync
Post your code?
Unread 13-01-2016, 21:57
FRC #5837
Here is the current code we are using, for a controller we are using the Logitech X30 flight stick.
package org.usfirst.frc.team5837.robot;
import edu.wpi.first.wpilibj.CameraServer;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Victor;
public class Robot extends IterativeRobot {
	Victor R_Motor = new Victor(1);
	Victor L_Motor = new Victor(0);
	RobotDrive chassis = new RobotDrive(R_Motor ,L_Motor);
	Joystick drive = new Joystick(0);
	int autoLoopCounter;
	double yAxis = drive.getY();
	double xAxis = drive.getX();
	double slider = drive.getRawAxis(3);
	double yMath;
	double xMath;
	double sliderMath;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
    	CameraServer server = CameraServer.getInstance();
    	server.setQuality(50);
    	server.startAutomaticCapture("cam0");
     * This function is called once each time the robot enters Disabled mode.
     * You can use it to reset any subsystem information you want to clear when
	 * the robot is disabled.
    public void disabledInit(){
	public void disabledPeriodic() {
    public void autonomousInit() {
    	autoLoopCounter = 0;
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
    public void teleopInit() {
     * This function is called periodically during operator control
    public void teleopPeriodic() {
    	sliderMath = Math.abs((slider-1)/2);
    	if (Math.abs(xAxis) < 0.25) {
    		xMath = 0;
    	else {
    		xMath = Math.signum(xAxis)*(Math.abs(xAxis) - .25)*1.333*sliderMath;
    	if (Math.abs(yAxis) < 0.25){
    		yMath = 0;
    	else {
    		yMath = Math.signum(yAxis)*(Math.abs(yAxis) - .25)*1.333*sliderMath;
    	if (drive.getRawButton(2)){
       chassis.arcadeDrive(yMath, xMath);
    public void testPeriodic() {
Unread 13-01-2016, 22:00
Jared's Avatar
Jared Jared is offline
You can calibrate your speed controllers to fix this. If you look online, you can find a manual for your speed controller that should explain how.
Unread 13-01-2016, 22:07
FRC #5837
But when I go into reverse the motor that starts first switches to the other motor; it isn't motor specific or even controller specific. More so which virtual motor it correlates to. Would calibrating the motors still fix this?
Unread 13-01-2016, 22:10
Jared's Avatar
That makes sense if the controllers aren't calibrated.
The PWM controllers have a small deadband where they will give no power. If one controller considers the zero point to be slightly ahead of where it should be, it will be late to start when going forward and early to start when going backward.
Unread 13-01-2016, 22:14
FRC #5837
Even if when I change motor controllers, meaning the on that previously started before and the one that started later are switched, the problem still happens with the same virtual motor.
Unread 13-01-2016, 22:27
Jared's Avatar
Try calibrating the joystick?
Unread 13-01-2016, 22:30
FRC #5837
We have used the slider Axis on the front bottom in order to have no side to side input and the problem still occurred. Also we have a dead zone and using the control panel to have it as centered as possible it still happened. I'm wondering if the error is inside the RobotDrive function provided by FIRST that one motor doesn't start as soon. Thank you for helping, all ideas help; We will definitely calibrate them first thing tomorrow as well.
Unread 14-01-2016, 00:02
virtuald's Avatar
RobotPy Guy
Sounds like something is lagging. I would try disabling the camera stuff.
Unread 14-01-2016, 00:54
What type of speed controller are you using?
Unread 14-01-2016, 07:59
FRC #5837
Victor SP controllers, and the camera isn't currently being used but I'll definitely comment it out for now.
Unread 14-01-2016, 10:33
virtuald's Avatar
RobotPy Guy
Well, there's your problem. You created Victor objects, not VictorSP objects. Try changing them to VictorSP.
Unread 14-01-2016, 11:44
FRC #5837
I'll change that, would that cause the motors to be set different values?
Unread 14-01-2016, 12:07
virtuald's Avatar
RobotPy Guy
Yes, the PWM timing is different.
