Go to Post And THAT is why they have safety manuals. - Eria4044 [more]
Unread 14-01-2016, 01:12
diegomedina57 diegomedina57 is offline
Rookie Year: 2016
diegomedina57 is an unknown quantity at this point
Pneumatic Trouble
Hey Guys,
We are a second year team! I was wondering if there are any pressure regulators that can release pressure when it is passed its set limit because we have this problem where if we do not use our intakes, the pressure builds up and one of the pipes connected to any pneumatic part will pop out.
Thank you!
Unread 14-01-2016, 01:18
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Pneumatic Trouble
Originally Posted by diegomedina57 View Post
Hey Guys,
Thank you!
the pressure switch usually included in your KoP automatically cuts power to your compressor when pressure gets over 120 psi. You need to connect the switch in the right place on your PCM (Pneumatics control module), which was included in last year's KoP
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 14-01-2016, 01:33
Rookie Year: 2016
thx bud
Unread 14-01-2016, 07:29
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Hey Guys,
Thank you!
There's also a pressure relief valve that MUST be attached to your compressor, and set to release air at 125 psi or less. See R87; also the various diagrams scattered through the pneumatics section of the rules.
Mentor http://www.teamtitanium.org/
Unread 14-01-2016, 08:12
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
If you are building pressure until the hoses come out of the fittings, something sounds very wrong. Be sure to reference section 4.11 of the game manual regarding the Pneumatic system. Pay particular attention to figure 4-15 to be sure you are using the proper safety devices and they are connected in the right places. Allowing pressure to build up until things fail is seriously dangerous.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 14-01-2016, 08:23
The required pressure regulator is a "relieving regulator" meaning that any pressure on the output side that exceeds the 60 psi will be passed to atmosphere. Generally high pressure will not be enough to push a hose out of a fitting. I suspect you have a defective retention device or the hose is just not seated.
R82 “Working” air pressure on the ROBOT must be no greater than 60 psi and must be provided
through a single primary adjustable, relieving, pressure regulator.
Norgren regulator P/N: R07-100-RNEA or Monnier P/N: 101-3002-1
recommended.
Unread 14-01-2016, 14:24
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Hey diegomedina57,
Is the compressor connected to the PCM's COMP-OUT connector? PCM will turn off the compressor when the comp-switch signals pressure is full.
Is the compressor-switch connected to PCM's PRESSURE_SW input? What if you disconnect the compress-switch, does the compressor still activate? If so inspect the involved wires and connection points for any shorts.
