Go to Post Don't fight bureaucratic morons... embrace them! Humour and publicity will take care of the rest. - dtengineering [more]
Unread 13-01-2016, 18:46
MAXOFLIFE's Avatar
MAXOFLIFE MAXOFLIFE is offline
Bolton Bear Bots Member
AKA: Maxwell Huffman
FRC #3666 (Bolton Bear Bots)
MAXOFLIFE is an unknown quantity at this point
Help with CIM motor locking system?
Sirius Reveal: https://www.youtube.com/watch?v=zxG7JpejR4g
Can someone tell me the name of the device that the robot Sirius uses in this video to control their arm? Their arm device is rotated using a CIM motor. If I'm not mistaken, CIM motors do not stay in place as Sirius's arm does when lifted off the resting position. Are they using some sort of gear box that locks the arm in any position in the given rotation? Or does a CIM motor have some kind of idle when powered and connected to a motor controller?
Thank you for taking the time to read this post! Any help is greatly appreciated .
Unread 13-01-2016, 20:11
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of lightjojoguy10 is a glorious beacon of light
Re: Help with CIM motor locking system?
I'm pretty sure they are using the Dart Linear Actuators. You can find them on their website: http://dartactuators.com/
Or, on Andymark: http://www.andymark.com/DART-s/540.htm
Unread 14-01-2016, 01:42
MAXOFLIFE's Avatar
According to a comment left on the youtube video, a CIM motor powers the arm and controls its angle. Do you know what we would need in order to replicate what they're doing? I was under the impression that this wouldn't work since a CIM motor doesn't lock into place when not power.
Unread 14-01-2016, 01:49
Knufire Knufire is online now
Sometimes it does, sometimes it doesn't. It's all dependent on the efficiency (friction) in the components (gears, belts, chain, etc) between the CIM and what you're trying to rotate.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 14-01-2016, 01:58
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is online now
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
they could be using sensors to read the arm's angle. You just have to apply a small portion of the available power using motor controllers (Talons, victors, sparks, etc.) to overcome gravity and keep it at the right angle.
I recommend you read about sensors and motion control for your personal knowledge
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 14-01-2016, 02:18
zinthorne's Avatar
zinthorne zinthorne is offline
AKA: Avery
FRC #5827 (Code Purple)
zinthorne will become famous soon enough
I believe the dart actuators are a worm drive system, and it's is very difficult or impossible to back drive a worm drive.
Unread 14-01-2016, 03:16
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Actually, the DART actuators use a ACME lead screw. Nevertheless, it's very difficult or impossible to backdrive a lead screw. On the other hand, efficiency goes down (Andymark says it's 52%).
Unread 14-01-2016, 06:22
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
There is a setting on the Motor Controller that allows or resists free wheeling of the motor. It is called "brake" or "coast" mode. That mode may provide enough resistance to prevent the arm from moving.
You can also use encoders on the motor to PID control the position to hold the arm in place.
Unread 14-01-2016, 07:41
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Placing a CIM in brake will not stop it completely. Brake mode turns the permanent magnet motor into a permanent magnet generator.
What you can do is operate the CIM at stall (using a PID for instance) and hold an arm in place. We did this a few years ago with our drive train a few years ago.
Unread 14-01-2016, 09:31
CryptoStorm's Avatar
CryptoStorm CryptoStorm is offline
EIC Tech
AKA: Joshua Stilwell
FRC #5056 (MegaHurtz)
CryptoStorm is an unknown quantity at this point
If you look at the video its clearly a cim connected to a standard gear box. a chain and sprockets deliver torque to a shaft going through the arm..
Its too hard to follow, however, if it were me and i was using this setup:
I'd attach a single turn pot to the end of the arm shaft and create a PID program to control the CIM output to match the analog value of the pot to a user defined value. pressing up increases the user defined value, pressing down decreases it.
