Re: [FRC] Laser pointer
We tried to use a Class 1 laser a few years back for visual targeting. It was totally useless and almost impossible for the driver to see. The flashlight idea works much better.
Also the cross hair linked above is a class 2 or 3 "laser" so it is not legal per saft rules. However I will keep it in mind when arming my sharks with "lasers". |
Due to the restrictions on Laser Pointers, teams have used "photon cannons" (basically, BRIGHT flashlights) with focused beams. Mind you, there are still rules against blinding the opposing alliance (you're free to blind yourself).
BTW, when deciding on illumination, please consider the effect on other drivers. If your choice is determined to interfere with the sight of other drivers, you might be asked to remove or modify. R9 ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS. See the blue box. Last edited by Al Skierkiewicz : 14-01-2016 at 08:17. |
