#12
Re: We are going to Want a GRIP fourm
Hi Everyone,
My team has succeeded at making a GRIP vision script, loading it to the RIO and getting the values out of the network tables. the only thing that i now want to do is be able to controll the launching and stopping of grip from my code (instead of using the GRIP UI application) some things we tripped on getting this this point: -The Grip deploy process ---when you deploy make sure your settings are your robot's address ---after you deploy there is a delay (about a min) then a NEW button appears just above the deploy log window (it looks like the "play" triangle) Push this button to run the GRIP process in headless mode on the rio.. No data will be published to the network tables till you do this step. NetworkTables ---Despite the fact i told my last step in the GRIP script to publish to "Vision" which would translate to "GRIP/Vision" in networkTables .. it didnt use my value.. instead only the default value provided by the step appears to work. in out case this was a contours publish so its "GRIP/myContoursReport" Another Note: GRIP will have dedicated control of the camera.. Any attempts to stream the camera after grip has started will failed with an "in use" error. If your already streaming its likely grip wont be able to access the camera and will silently fail. If any team is looking as to how to use GRIP to do targeting i would be happy to provide a plain english write up on how we are approaching this problem and how you can use grip to solve it. Last edited by jmguillemette : 14-01-2016 at 09:56. Reason: Typos.. many typos... |
