#18
Re: Ri3D 1.0 Robot Reveal 2016
I believe that with some small modifications this scaling method could still be legal. Making the tower that the arm rotates from taller (so the point it contacts on the wall is up closer to the bar and the arm doesn't need to be as long) or using a long oriented chassis (so that the arm could be longer and the longer frame perimeter would keep more of it inside the robot) would both seem to fix this issue.
