Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 14-01-2016, 10:18
4373Henry's Avatar
4373Henry 4373Henry is offline
FRC #4373
4373Henry is an unknown quantity at this point
Re: [Question] Library on roboRIO appears to be missing
Originally Posted by fsilberberg View Post
You need to update the image on your RoboRIO. That's the reason why the build was failing: your RoboRIO is out of date. See the ScreenSteps here https://wpilib.screenstepslive.com/s...g-your-roborio.
I already followed those steps. Is 3.0.0f0 not the latest version?
