Go to Post Dr. Doom becomes Dr. Awesome! - Nick Lawrence [more]
Unread 14-01-2016, 10:37
Professional Stat Padder
67's 2010 Climber
I was trying to find details on HOT's climber back in 2010 and how it was able to scale even after the end of the match. I couldn't find the relevant details on CD or their website. Can anyone direct me in the right direction?
From my understanding there was some sort of gas spring that made the climber normally closed so that once it was hooked on, even if the match ended, it would finish scaling. We discussed how to ppossibly build a climber to do that but we're stuck on exactly how to go about it.
(2015-Present)
Unread 14-01-2016, 10:45
pfreivald's Avatar
AKA: Patrick Freivald
Re: 67's 2010 Climber
Any sufficient amount of energy stored in an elongation should do it. Whatever your raising device is can be linked (mechanically or electrically) to release a restraint keeping your stored energy device (gas spring, spring, surgical tubing, whatever) extended. Once released by the claw's contact with the bar, the device will contract automatically and without further input from the rest of the robot.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-01-2016, 10:55
FRC #1836 (MilkenKnights)
Post Re: 67's 2010 Climber
My understanding is that SCALING a tower only counts if it happens before the match ends.
3.1.4 The Tower
A ROBOT has SCALED the TOWER if, at the conclusion of the MATCH, the ROBOT:
A. is in contact with a unique RUNG, and
B. has all of its BUMPERS fully above the height of the low GOALS.
Unread 14-01-2016, 10:56
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Related question - Are you allowed to make your own "gas springs" by pressurizing and capping one end of an air cylinder to, say, 100 psi? Since it would be completely disconnected from the pneumatic system, could you avoid the 60psi limit and venting requirements of the FRC pneumatics rules? It would be very similar to buying a commercial gas spring, only less pressure and easier to integrate.
Unread 14-01-2016, 10:58
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Just to add more context to this thread.
Video of 67 climbing on Einstein. https://www.thebluealliance.com/match/2010cmp_f1m2
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 14-01-2016, 11:05
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Just need to read a little bit further, section 3.3.1:
Originally Posted by 3.3.1 Point Values
The final assessment of ROBOTS having SCALED or CHALLENGED the TOWER is made five (5) seconds
after the ARENA timer displays zero (0), or when all ROBOTS have come to rest following the conclusion
of the MATCH, whichever happens first.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
Manual Section 3.3.1, Scales or Challenges are assessed 5 seconds after a match, or when all robots come to a rest - whichever comes first.
Academic Student (Forever)
Unread 14-01-2016, 11:08
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
I would infer from that, that robots can use the 5 seconds after the match to complete the climb. Probably a good Q/A question though.
Unread 14-01-2016, 11:29
george.tan's Avatar
george.tan george.tan is offline
Raider Power!
AKA: George
FRC #3005 (RoboChargers)
george.tan is on a distinguished road
Originally Posted by BrendanB View Post
From 3.3.1
It basically means that your robot have to hold its position for at least 5 seconds after the field is disabled. In case your robot does not have a firm grip on the RUNG and fell off immediately after, then that does not count.
Unread 14-01-2016, 11:30
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
It technically means both: if robots can maintain being scaled or if they are rising from stored assistance.
1058 PVC Pirates 2016 - xxxx
Unread 14-01-2016, 11:38
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Not to be coarse, but can we get back to OP's original topic rather than arguing about the meaning of rules. Q&A is where that debate belongs.
I myself have also looked for any form of legislation regarding their 2010 end game but have come up empty handed. ):
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 14-01-2016, 11:39
The problem I'm having is how to have enough force in that stored energy to lift the 120+ lb robot up and have it a) be able to be held back by something simple, b) have it not be gigantic (weight-wise or volume-wise)and c) have it be relatively safe for students to assemble and test.
(2015-Present)
Unread 14-01-2016, 11:56
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Kevin,
I can't provide any helpful details, but here's the video I've been looking at recently while trying to understand their approach: https://www.youtube.com/watch?v=JI3N...=youtu.be&t=89.
Unread 14-01-2016, 12:00
pfreivald's Avatar
Anything storing ~400 joules of PE is going to be somewhat dangerous to test (and perhaps to build). Depending on how clever you get, four 40-lb constant force springs from McMaster-Carr should get a robot off the ground if you hook them to a strap which you hook over the bar.
Between a ~30" long robot that's ~30" tall, you should be able to preload four of these (http://www.mcmaster.com/#9293k14/=10ohghg) on a (loose) strap that you lift up to the bar, and allow them to retract most of that 60". Pull a pin (or release a cam) and, uh, shoom!
(Not necessarily the best idea. I think you could go rather lighter if you just used a winch; but you certainly could use these, or surgical tubing, or maybe just some big honkin' coil springs. The key notion here is to hook on while something else is taking the pre-load, then release that something else to let the pre-load lift the bot.)
Team 1551
I write books, too!
Unread 14-01-2016, 12:13
jeremy callahan's Avatar
jeremy callahan jeremy callahan is offline
FRC #5053
jeremy callahan will become famous soon enough
Here is 67's engineering notebook I haven't looked at it but after every year hot puts together a notebook so you can review there designs afterwards if you would like. Hope this helps.
http://www.hotteam67.org/Archive/EngineeringDesign.html
