Go to Post If you want to use the don't ask, don't tell logic about asking then you know it is wrong. - Steve W [more]
Unread 14-01-2016, 10:11
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Team Version Rough Terrain Inaccuracies
It appears that the Team Version Rough Terrain measurements differ a decent amount from those of the official field.
In the Team Version document, they suggest making the blocks each 3.5" x 3.5", spaced 1" apart:
However, on the official field, the blocks are 3" x 3", spaced 1.5" apart:
The plate they are on also appears to be 50" long on the real field, giving some extra space on each side of the end blocks (while the Team Version base is only 48" long):
For teams that have built a Rough Terrain to practice on, have you been keeping true to the Team Version measurements, who did you alter its construction to make it more similar to the official version? Do you believe there is a noticeable difference?
Unread 14-01-2016, 10:14
TJP123 TJP123 is online now
AKA: Tom Pospeshil
FRC #0503 (Frog Force)
TJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant futureTJP123 has a brilliant future
Re: Team Version Rough Terrain Inaccuracies
We ripped the 4x4 lumber down to 3" and used the correct gap measurements.
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
We plan on adjusting the team version slightly. Making the correct spacing for the squares (3x3 1.5 inch apart) but keeping it 48" long. The team version is shorter then the real deal so that part of it is fine.
Unread 14-01-2016, 10:15
AdamHeard's Avatar
Lead Mentor
Biggest difference is the moat for sure.
Wood moat is fairly easy, metal moat is much harder.
Unread 14-01-2016, 10:22
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Why do you say that?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 14-01-2016, 10:25
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Probably because the actual field is smooth steel and the team version is rough wood.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 14-01-2016, 10:26
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is online now
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
I'm going to take a stab at it and guess it's because metal is less grippy.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 14-01-2016, 11:16
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Thanks for sharing this, just knowing there's a big difference is a big deal ... any chance you guys could post a video without giving away your secrets? I'm going to see if I can get our guys to swap our materials around tonight.
edit - any by 'swap around' I mean we'll form 1/16" aluminum sheet metal around the moat wood pieces.
GitHub
Unread 14-01-2016, 11:35
AdamHeard's Avatar
Lead Mentor
I don't have any videos we could share, but the difference seems to be traction. You simply get more bite on wood than metal.
Unread 14-01-2016, 11:43
Professional Stat Padder
Well that's annoying. Thanks for pointing this out.
(2015-Present)
Unread 14-01-2016, 11:47
JesseK's Avatar
FRC #1885 (ILITE)
Alright, time for some flying robots then.
GitHub
Unread 14-01-2016, 15:03
pfreivald's Avatar
AKA: Patrick Freivald
The 1" gap (team) vs a 1.5" gap (official) is brutal, given how many 1" wide wheels there are out there. Having a wheel fall between two blocks could have terrible ramifications for some drive trains--whether it jams, or you try to turn while it's in there.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-01-2016, 18:08
2544HCRC's Avatar
2544HCRC 2544HCRC is offline
FRC #2544 (HCRC)
2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about2544HCRC has a spectacular aura about
The smoothness issue is a big concern. The same thing occurred with the coopertition bridges a few years ago. Teams built wooden bridges and field dividers that were no problem at home. The real bridges had a smooth plastic surface and the divider was metal. The difference was huge for teams.
