Go to Post There will be violence next year! YAY! - Koko Ed [more]
Unread 10-01-2016, 15:31
Tymethy's Avatar
Tymethy Tymethy is offline
Scouting Captain
AKA: Tymothy
FRC #3824
Tymethy is an unknown quantity at this point
Loophole in rule G39 and G43 for defense??? (Repost due to edits)
G39:"ROBOTS are prohibited from launching BOULDERS unless they are in contact with the opponent’s
TOWER or carpet in the opponent’s COURTYARD, and not in contact with any other carpet.
Violation: TECH FOUL per BOULDER"
The rule states that you may not launch a boulder unless in contact with the courtyard (not fully within the courtyard). Does this mean that you are allowed to be partly within the outerworks while launching.
I ask this because under rule G43:
"ROBOTS on the same half of the FIELD as their ALLIANCE TOWER may not interfere with
opponent ROBOTS attempting to traverse OUTER WORKS (regardless of direction). A ROBOT is
considered traversing the opponent’s OUTER WORKS if any part of its BUMPERS are within the
opponent’s OUTER WORKS.
Violation: FOUL. For every five (5) seconds in which the situation is not corrected, FOUL"
You can not be defended while even partly within the outerworks. The outworks is not a carpeted area so does it count because it states "and not in contact with any other carpet." Does this make this halfway area a safe spot. This does not seem intended due to other rules of defense and want to ask due to this.
Thank you for your time.
(ADDED NOTES)
Does this not also break G11:
"Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of
FIRST Robotics Competition and not allowed. Rule violations forced in this manner will not result in
an assignment of a penalty to the targeted ALLIANCE.
Violation: FOUL. If egregious or repeated, YELLOW CARD"
Or G40:
"A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s
COURTYARD unless:
A. the ROBOT contacts the BOULDER within OUTER WORKS, and
B. the ROBOT completes its CROSSING (i.e. doesn’t completely back out of the OUTER
WORKS into the NEUTRAL ZONE)
Because with G40 you must be fully crossed for that boulder to be counted within the courtyard. So can you shoot it if the object (boulder) is technically not within the courtyard based on the rules. (Rule G40 can be fixed by going all the way through then backing into the outerworks after the completed cross. Rule G11 still stands.)
Unread 10-01-2016, 15:43
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Loophole in rule G39 and G43 for defense??? (Repost due to edits)
Yes, you can be partially in the Outerworks and launch the Boulder.
However, G40 implies that the robot must fully enter the courtyard (either before or after launching the boulder) to avoid the penalty. A good question for the Q&A.
Note: this also gives the offensive robot a "safe zone" to avoid contact from a defending robot.
AndyBare AndyBare is online now
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Yeah. You must just fully cross before backing up and shooting. You can shoot from "mostly the outer works" however you must be touching the courtyard's carpet and only the courtyard's CARPET aka no other carpets (etc. neutral zone)
Unread 10-01-2016, 15:56
Tymethy's Avatar
Scouting Captain
AKA: Tymothy
FRC #3824
Thank you for your thoughts.
Unread 10-01-2016, 15:57
Tymethy's Avatar
Scouting Captain
AKA: Tymothy
FRC #3824
Unread 10-01-2016, 17:06
Basel A's Avatar
Basel A Basel A is online now
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
We identified this as well. There are concerns with traversing vs. attempting to traverse, but I believe that if you are traversing (your bumper is partly within the outer works), a referee will have to count that as attempting to traverse. This feels like a loophole, but "any other carpet" seems like very intentional wording to allow it.
G40 doesn't get in the way as long as you fully enter the courtyard either before or after your shot. Not much of a problem, if you ask me.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 14-01-2016, 11:58
DWNichols DWNichols is offline
FRC #2836
DWNichols is an unknown quantity at this point
My only concern is the phrase "attempting to traverse OUTER WORKS". If you are actively aiming and shooting, are you still attempting to traverse the defenses? Definitely a question that should be asked.
Unread 14-01-2016, 12:05
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The act of multi-tasking is not explicitly listed as an exception to the fact that the bumpers are still over the outer works.
GitHub
Unread 14-01-2016, 12:11
Zach101's Avatar
Zach101 Zach101 is offline
Oh captain, my captain
AKA: Zach Hagen
FRC #2512 (Duluth East Daredevils)
Team Role: Tactician
Zach101 has a spectacular aura aboutZach101 has a spectacular aura aboutZach101 has a spectacular aura about
This would be a very interesting loophole. I have taken it as you need to be fully in the courtyard to shoot but this would be a great thing to take advantage of unless FIRST changes it.
2015 MSHSL State Championship Winners with 3130 and 4215
2015 Hopper Division Winners & Einstein Finalists with 987, 2826, and 4265
2015 Northern Lights Chairman's Award Winners
Finalists at the 2015 Central Illinois Regional with 4143 and 4212
Finalists at the 2015 Northern Lights Regional with 5172 and 4786
2015 Prior Lake Mini Regional Winners with 2169 and 4859
2014:Strategy 2015:Electrical 2016:Strategy Captain
<Hopper Division Announcer> 'When I said Admiral, you say Hopper... Admiral! Ackbar!
Unread 14-01-2016, 15:09
FRC #2836
Multi-tasking isn't an issue for me. I'd love to see a robot design that can accurately shoot while travelling over an outer defense. But, if you are just sitting on, or your bumper is over, a defense, and your drive train is not driving, are you "traversing"? That's the important question.
Unread 14-01-2016, 15:15
Basel A's Avatar
AKA: @BaselThe2nd
Relevant Q&A below. Sounds like there'll be clarification in the next team update.
Originally Posted by Q511
Q. Per G43, ROBOTS are not allowed to interfere with opponents attempting to traverse the OUTER WORKS. What constitutes as "interfering with an attempt?" Does the my opponent's ROBOT have to already be in the act of traversing the OUTER WORKS per the definition of G43, or is peventing them from reaching the OUTER WORKS considered "interfering with an attempt"?
A. Good question. The rule was written with the intent being that a ROBOT attempting to traverse was in the process of traversing, but that language isn't consistent with our actual intent. Team Update 02 will update G43 to clarify that ROBOTS on the same half of the FIELD as their ALLIANCE TOWER may not interfere with opponent ROBOTS traversing OUTER WORKS (regardless of direction). Our apologies for the confusion.
-Paul Copioli
Unread 14-01-2016, 15:16
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I interpreted this as an intentional design choice, similar to being "protected" while shooting while in contact with the pyramid in 2013.
Unread 14-01-2016, 15:38
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Thank you for finding and posting that Q&A here. I don't think the people posing the question really understood the wording of the rule, (seeing as they asked about the "interfering with an attempt?" but the rule prohibits interfering with a robot that is making an attempt) but they still seems to have yielded an informative response.
Yes. I think the GDC intended for that area to be a safe zone, because without it this game would not play as well.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 14-01-2016, 21:59
Lord Basket's Avatar
Lord Basket Lord Basket is offline
President & Drive team coach
AKA: Parker
FRC #1719 (The Umbrella Corporation)
Lord Basket has a spectacular aura aboutLord Basket has a spectacular aura aboutLord Basket has a spectacular aura about
Looks like even with that clarification taken into consideration, the safe zone will still work, as long as you keep going in the direction you were moving in at the time when you entered the defense.
Unread 14-01-2016, 22:48
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
I'm interpreting it as a safe zone, but I can picture the field elements getting damaged due to defense in those areas otherwise.
