Go to Post Don't be too arrogant as to think that just because you didn't invent it, it is not useful. - ptan [more]
Unread 13-01-2016, 22:09
mattknight2447 mattknight2447 is offline
FRC #6171
mattknight2447 is an unknown quantity at this point
HELP NEEDED WITH PHYSICS
Greeting from Rookie team 6171! We are building our robot for this year's Stronghold theme and we plan on going with a dual or quad flywheel idea to launch a ball into a hole. We need some help determining the angle to shoot from given a constant velocity and RPM (for each flywheel). Any help is much appreciated as this is our first year doing this. Thank you!
The work we have so far is attached to this thread
Most of the information can also be found on this closed thread
http://www.chiefdelphi.com/forums/sh...ad.php?t=99797
Unread 13-01-2016, 22:25
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: HELP NEEDED WITH PHYSICS
http://www.chiefdelphi.com/media/papers/2725
This white paper by Ether includes Magnus effects, which are often important in the design of spinning-wheel type ball shooters.
Richard Wallace
since 2003
Last edited by Richard Wallace : 14-01-2016 at 12:35. Reason: hopefully clearer now
Unread 13-01-2016, 22:27
FRC #6171
yes sir! credit was goven in my post ^^^
Unread 13-01-2016, 22:40
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
here is what I can give you, this these spread sheets are made to do a couple different things
this first one has 3 sheets
https://drive.google.com/open?id=1y8...iKumt0ZtPqlaZE
sheet 1: given a launch angle and velocity the sheet outputs the flight path of the ball, you can play around with things here to get what you want, does not include drag
sheet 2: you tell this sheet a launch angle and a target height and it outputs the required launch velocity for a bunch of different distances.
sheet 3: this one does the same thing as sheet 2 but it accounts for drag
second set also has 2 sheets, but only the first one applies to your problem
https://drive.google.com/open?id=1oK...KUVSOSr8OS MA
here you input launch angle and launch velocity and it outputs the path of a projectile, however this one accounts for drag. note this one is a work in progress, I cannot 100% guarantee it's accuracy, but I know it is close, and also the calculations for max height, time in air, and final x position are not currently working, but the trajectory calculator is
Unread 14-01-2016, 12:32
Originally Posted by gblake View Post
Read about the Magnus effect before you finish your design work.
Thank you, Blake. That was my reason for linking to Ether's 2012 white paper.
@Matt: I apologize for my sloppy communication. You credited earlier work perfectly; I was only pointing out some nicely presented physics from Ether.
Richard Wallace
since 2003
