Go to Post To be blunt: how many motorized carts do you see parked on the side of Einstein? - Koko Ed [more]
Unread 14-01-2016, 13:54
Kuriki Kuriki is offline
Programmer, Driver, Captain
AKA: Kyrel Jerome
FRC #5288 (Spartan Robotics)
Kuriki is an unknown quantity at this point
Cannot Upload code to Robot
"Buildfile: D:\New folder\RobotIn6Hours\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory D:\New folder\RobotIn6Hours\build
compile:
[mkdir] Created dir: D:\New folder\RobotIn6Hours\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\kyrel_000/wpilib/java/current/lib/WPILib.jar:C:\Users\kyrel_000/wpilib/java/current/lib/NetworkTables.jar: to build
BUILD FAILED
C:\Users\kyrel_000\wpilib\java\current\ant\build.x ml:71: Unable to find a javac compiler;
com.sun.tools.javac.Main is not on the classpath.
Perhaps JAVA_HOME does not point to the JDK.
It is currently set to "C:\Program Files\Java\jre1.8.0_65"
Total time: 454 milliseconds"
What does all this mean? I'm new to FRC programing and don't understand what the problem here is.
Thanks if anyone can help us out
Unread 14-01-2016, 16:57
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: Cannot Upload code to Robot
It looks like you've installed, the JRE, not the JDK. Follow the instructions for installing Java on the ScreenSteps: http://wpilib.screenstepslive.com/s/...eclipse-c-java
