Go to Post Robots can be fixed, glory is forever - Brandon Holley [more]
  #31   Spotlight this post!
Unread 14-01-2016, 10:17
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
Re: We are going to Want a GRIP fourm
Maybe to fix the problem of Grip vs Streaming the Grip app should generate a Java / C++ / your language script similar to RobotBuilder to insert directly into the code. Then They can share the same capture frames.
  #32   Spotlight this post!
Unread 14-01-2016, 10:45
jmguillemette jmguillemette is offline
FRC #4525
jmguillemette is an unknown quantity at this point
Can you clear up a few steps leading up to this.
1. When developing the Grip script where is the camera connected? PC/Rio USB/IP Web cam
2. On the PC what is the Camera Name? Cam0.1.2....
3. If USB what is the USB camera name when viewing the WebDashboard?
4. What is the Deploy address you are useing?
1. While developing the script the camera is connected to the pc running GRIP.. after the script is done, i move the camera to the USB port on the rio and then deploy the script to the rio.
2. Im lucky that even with the on board camera built into my laptop the usb camera we are using get identified as camera0 consistently when used on the RIO and on my laptop.
3. the process for getting the camera on the smartDashboard is entirely separate from using GRIP and thus they actually will conflict with one another.
The strategy when using grip is to do the analysis of the image on the RIO and then only transmit the raw numerical data back to dash to assist the driver via indicators.
4. roborio-4525-frc.local
I have never waited for the PC deploy and didn't know I would have an option to start the script on the Robot from the PC. I'll check that out.
let me clarify this. GRIP is a separate program from your Robot. Within the GRIP development UI there is the ability to deploy.. and after a brief wait a play button will appear to launch the GRIP script on the RIO.
A GRIP script should include as its last step one of the RIO publish tasks. These push data to the networkTables mechanism that your Robot code can access.
There are thus separate applications that talk via the networkTables.
  #33   Spotlight this post!
Unread 14-01-2016, 10:46
FRC #4525
agreed.. i would like to embedded grip vs having to call to runtime to start yet another java application.. from my java application.
  #34   Spotlight this post!
Unread 14-01-2016, 11:50
Rookie Year: 2015
Originally Posted by jmguillemette View Post
Hi Everyone,
Another Note:
GRIP will have dedicated control of the camera.. Any attempts to stream the camera after grip has started will failed with an "in use" error. If your already streaming its likely grip wont be able to access the camera and will silently fail.
Scary.. I have had limited success deploying and running grip on the Rio. If the NetworkTable has old data it will not clear. How I see it if Grip does't launch you maybe acting on OLD DATA.
  #35   Spotlight this post!
Unread 14-01-2016, 12:24
FRC #4525
for the data to be good to the driver or autonomous system is needs to be constantly updating.. .if you see static numbers.. youll know somethings up.
  #36   Spotlight this post!
Unread 14-01-2016, 12:51
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Can we not stream and us Grip at the same time?
If it's a USB webcam, probably not. I don't think multiple applications can access a USB webcam on linux at the same time.
One planned feature for the next minor version of GRIP is a "publish image" operation. That should let you look at any image in your pipeline using SmartDashboard.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
  #37   Spotlight this post!
Unread 14-01-2016, 12:52
krieck's Avatar
krieck krieck is offline
AKA: Keith
FRC #2846 (Firebears)
krieck is an unknown quantity at this point
I see the option for deploying a GRIP pipeline to the roboRIO. However, I'd like to try running my pipeline on a Raspberry Pi.
Is there an easy way to simply generate the pipeline's grip.jar file onto my local filesystem?
  #38   Spotlight this post!
Unread 14-01-2016, 12:55
Rookie Year: 2015
Seen that in the issues tab of the project #355. Would help heaps. Also is there talk about adding blocks to get data from the SmartDashboard to get values to plug into the slider controls to dynamically control the filters from the Robot or Smartdashboard?
  #39   Spotlight this post!
Unread 14-01-2016, 13:19
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
I love the discussion going on. I've challenged our programming team with GRIP. I've asked them to give a short presentation to the team leaders and mentors about GRIP. What is it, what can it do, what are the pain points, and how can it make our bot better.
My first thought is to run it on a Raspberry Pi too. But we'll see. With all the talk in here, I think they'll get a good feel of what to expect. It might be interesting to spin up an IRC chat room in the evenings for help/advice, if there is interest in it. Being an alpha version, we're all experiencing growing pains.
Brian
  #40   Spotlight this post!
Unread 14-01-2016, 13:35
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Help me out please... What is GRIP?
Can you point me to documentation/description?
The views expressed are mine and should not be construed to represent the views of anyone else.
  #41   Spotlight this post!
Unread 14-01-2016, 13:54
FRC #1261
GRIPis GRaphical Iage Processing. It allows easy creation of 'pipelines' that will allow you to identify objects. It's not apart of your robot code, but is a separate program. After getting things setup, you then have to connect the data from GRIP to your robot software.
Jojoguy10 posted a link for more information: http://wpilib.screenstepslive.com/s/4485/m/50711
  #42   Spotlight this post!
Unread 14-01-2016, 13:55
Rookie Year: 2015
GRIP - Graphical Image Processing
  #43   Spotlight this post!
Unread 14-01-2016, 15:04
Ti-Gars's Avatar
Ti-Gars Ti-Gars is offline
Wizzard
FRC #3360 (Hyperion)
Ti-Gars is on a distinguished road
JAVA:
Runtime.getRuntime().exec(new String[]{"/usr/local/frc/JRE/bin/java", "-jar", "grip.jar", filename});
Is "filename" a variable in your code, or am I supossed to write something specific? If I only write filename, eclipse is showing me an error
  #44   Spotlight this post!
Unread 14-01-2016, 15:22
FRC #4525
Thomas
if you have insight into the inner working of GRIP..
can you provide a build of the existing version where by i can programmatically start (<here is my .grip file) and stop() grip.
suggesting we call out to an external process to run it means we have no control over grips lifecyle in relation to our robot.
  #45   Spotlight this post!
Unread 14-01-2016, 15:35
Rookie Year: 2015
I'm Quoting from https://github.com/WPIRoboticsProjec...va-FRC-program
In my code I created a variable to String filename = "myGripProgram.grip"; There is no documentation on how or why to do this I just assumed. It hasn't work for me yet.
