Go to Post Competitions are won or lost far away from witnesses, ... In those long hours, is where we find inspiration in ourselves. For what inspires is not another's feats, but realize we have the power in ourselves to achieve that feat. - Mark Sheridan [more]
Unread 14-01-2016, 15:31
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: Bumper clarification
From Q&A:
Q520
Q. Bumper rule R19 states "If a side is shorter than 8 in., the entire side must be protected by BUMPER". If the side is 27" with a 13" cut-out (14" remaining) does the 8" minimum apply or is the 7" on either side of the cut-out considered a full side less than 8"?
A. Per the Blue Box below R19: the dimension defined in R19 is measured along the FRAME PERIMETER. A lack of physical frame elements between corners of the FRAME PERIMETER does not change the length of the FRAME PERIMETER side.
