Go to Post Coaxial swerve modules with a suspension and differential aren't normal. But on Winnovation they are. - Andrew Schreiber [more]
Unread 14-01-2016, 17:03
The Ginger's Avatar
The Ginger The Ginger is offline
#GingerPower
FRC #5464 (BluejacketRobotics)
Team Role: Driver
Rookie Year: 2015
The Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud of
Number of CIM motors
In the rule book it states that you can have up to 6 CIM motors, but does that mean that you can have ONLY 6 CIM motors, or up to 6 of each different kind of CIM motors.
Unread 14-01-2016, 17:04
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Number of CIM motors
Please read the blue box of R29.
Unread 14-01-2016, 17:37
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
In addition to the bluebox, I'd like to point out that the miniCIM does not fall under the CIM category for motor count.
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 14-01-2016, 23:19
The Ginger's Avatar
#GingerPower
Team Role: Driver
Rookie Year: 2015
Well it list all of the CIM par numbers and to the right says 6, then it lists all the other part numbers and says unlimited. So I thought that it was saying "for the following u can have up to 6 of each" for the rest of them i thought it meant "for the following u can have as many as u like"
Unread 14-01-2016, 23:26
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Regardless of rules be careful of brownouts. I'm haven't checked but I believe you can have a max 6 Cims. We will be using 4 Cims, and 2 mini Cims this year plus a compressor. Got to admit I'm a little worried about brownouts.
Unread 14-01-2016, 23:31
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
You're allowed 6 CIMS. The big, coke-can sized black motor. The blue box (Table 4-1: Legal Motors) having multiple part # is because there's a strange amount of places that now sell CIMs, but at the core they're all basically the same, and you can have 6.
As far as other motors (mini-CIMs included), go nuts. Have as many as you wish, though bear in mind that your robot battery has to make it through a two and a half minute match.
@Sperkowsky, as long as your compressor is on sparingly, it sounds like that set up should be fine. Avoid pushing matches if you can, and hopefully you're never both completely refilling your tanks as well as shoving a robot across the field.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 14-01-2016, 23:33
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
This is the 2nd paragraph in the blue box under R29:
ThIs is the total number of each motor a Team may use on their ROBOT, not the quantity per part number. For example, each team may use up to six (6) CIM motors on their ROBOT, regardless of the quantity or combination of each individual part number used.
Mentor http://www.teamtitanium.org/
Unread 14-01-2016, 23:46
The Ginger's Avatar
#GingerPower
Team Role: Driver
Rookie Year: 2015
Got it, Thank ou for he help!
