Go to Post The folks in Indiana don't play around. - PayneTrain [more]
Unread 14-01-2016, 18:37
crashingacastle's Avatar
crashingacastle crashingacastle is offline
AKA: Blake Johnson
FRC #0829 (Digital Goats)
Rookie Year: 2015
crashingacastle is an unknown quantity at this point
Setting Variable from SmartDashboard or Driver Station
When testing shooters my team was hoping to use either SmartDashboard or the FRC Driver Station to set variables. We were hoping to be able to simply click and type a variable and change the speed of motors for testing purposes. How simple and how would we go about doing this?
Thank you for any help provided.
Unread 14-01-2016, 20:39
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Setting Variable from SmartDashboard or Driver Station
The variable has to be defined in code and sent to network tables before you can edit it on the smartdashboard.
For more information, refer to the docs here https://wpilib.screenstepslive.com/s/4485/m/26401
Unread 14-01-2016, 23:19
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
If you enable test mode with the SmartDashboard open, you should see subsystems and their components in the LiveWindow (assuming you're using robotbuilder). Otherwise you can call LiveWindow.addSpeedController(shooterMotor) or something along those lines
WPILib
GRIP, RobotBuilder
