Go to Post Build season is the best time of the year. Better than Christmas because the presents are cooler, and better than new years cause you get to stay up later. - burkey_turkey [more]
Unread 01-14-2016, 08:34 PM
amesmich's Avatar
amesmich amesmich is offline
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
Method to direct drive HEX Shaft
Does any one have a preferred method to join a CIM directly to HEX Shaft? Hub to hub? Or is there a better way?
Unread 01-14-2016, 08:35 PM
Knufire Knufire is offline
Re: Method to direct drive HEX Shaft
http://www.andymark.com/product-p/am-0588.htm
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 01-14-2016, 08:38 PM
REVving up for a new season
FRC #2848 (All-sparks)
hub to hub would work, but I think I would use one of these... http://www.andymark.com/product-p/am-0588.htm
and then use a hex to hex coupler or another power transmission method like chain or gears.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 01-14-2016, 08:44 PM
amesmich's Avatar
FRC #4638 (Jagbots)
I knew about the adapter but not the hex coupler. Thanks.
Unread 01-14-2016, 10:10 PM
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is online now
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
use caution if directly driving a load from the CIM output shaft. The "bearing" in the end is a bushing and it cannot handle any offset.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 01-14-2016, 10:16 PM
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Following on Chris's caveat, if you DO want to drive directly off a CIM 1:1, you can do it though a VEX Versa-Planetary, though it'll be a longer setup. You take out all the planetary stages, and the motor mount block bolts directly to the output block. To mount the CIM, you can either buy a CIM adapter from VEX, or cut down the CIM shaft an alarming amount.
Unread 01-14-2016, 10:52 PM
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
http://www.wcproducts.net/217-3255
Another item that can allow you to direct drive off a CIM.
R.C.
MadTown Robotics Team 1323
Unread 01-15-2016, 04:57 AM
RoboChair's Avatar
AKA: Devin Castellucci
drill a 5/16 inch hole in the end of the shaft on a lathe and press it in with a little superglue.
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 01-15-2016, 10:04 AM
philso philso is offline
FRC #2587
^ +1
These motors use sleeve bearings at both ends of the shaft. Excessive side forces on the shaft can and will damage one or the other. One of our team mates broke the bearings at the back end of a CIM that was direct driving a Frisbee shooter wheel when he used too much compression. It only took about 3 shots to damage it.
Kevin's suggestion to use the 1:1 Versa Planetary is the best of the solutions presented because the shaft in the VP has it's own bearings and they absorb the side forces and don't transmit them on to motor shaft.
Unread 01-15-2016, 10:20 AM
Chris is me's Avatar
AKA: Pinecone
If you have the hex shaft supported in some other way, a quick and dirty solution for protoyping purposes is to drill an 8mm hole in the end of the hex shaft and drop a set screw in it. For competition use, set screws should generally be avoided since they are not great at transmitting torque and tend to come loose exactly when you don't want them to.
The WCP or AndyMark hex adapters combined with Vex's hex coupler is another good way to do it, but again, a well supported hex shaft is essential to any solution.
Unread 01-15-2016, 10:45 AM
FRC #2587
Never had a set screw come loose in competition and mess us up. Never!!!
Have never used sets screws again for "high power" applications.
For prototyping, you can use a hand drill with a 1/2" chuck to drive the hex shaft. Much less to build.
Unread 01-15-2016, 01:02 PM
AKA: Pinecone
Most hand drills can't come close to matching the free speed of a CIM though (roughly 5400 rpm). This is a poor choice for prototyping a shooter.
Unread 01-15-2016, 01:17 PM
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
We are using a hand drill capable of 3000 rpm with an adapter and 1/2" hex socket that is working just fine for initial prototyping of a shooter.
Unread 01-15-2016, 02:29 PM
amesmich's Avatar
FRC #4638 (Jagbots)
I am aware of the lateral loads on CIMS. We are not trying to direct drive something with a hex opening we are trying to drive the shaft which is supported by its own bearings. The hex shaft to 8mm adapter really would not do it alone since we would need a coupler. I think we will 3d print a hub into our design and then bolt the 8mm CIM hub to that so its compact strong and clean. Thanks for the feedback.
Unread 01-15-2016, 02:32 PM
If you drill a 8mm hole in the shaft and make a cut lengthwise about half an inch into the shaft, you can put a collar clamp on the end which will cause the shaft to clamp the CIM shaft.
You can see a similar concept here: http://www.andymark.com/product-p/am-3185.htm
