Go to Post Uh. Oh. Wildstang is simple and has a swerve. Where have I seen that before? - EricH [more]
Unread 14-01-2016, 15:33
Team DRIFT Team DRIFT is offline
FRC #4091
Team DRIFT is an unknown quantity at this point
Bridge Configuration Utility not available in suite?
Our team has had trouble finding the Bridge Configuration Utility and the roboRIO Imaging Tool and we wanted to know if it was only us or everyone and if it is just us how we could find it and download it. We downloaded the Update Suite, and did the install. We even get the folder for the Bridge Configuration Utility showing up, but the actual Configuration Utility isn't coming up, only a text file. Thanks!
Unread 14-01-2016, 16:52
Klone38 Klone38 is offline
FRC #4486
Klone38 is an unknown quantity at this point
Re: Bridge Configuration Utility not available in suite?
For some reason they didn't include it this year and you have to download and install it separately. Probably because of the whole new radio thing or something. You can find it here https://usfirst.collab.net/sf/go/pro...ration_utility
Unread 14-01-2016, 21:18
The roboRIO Imaging Tool can be found under
C:\\Program Files\National Instruments\LabVIEW 2015\project\roboRIO Tool
Leave it where it is, but create a shortcut on the desktop for easier access.
Unread 14-01-2016, 21:31
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
Originally Posted by Mark McLeod View Post
The roboRIO Imaging Toolcan be found under
C:\\Program Files\National Instruments\LabVIEW 2015\project\roboRIO Imaging Tool
Was there a new update for the RIO? When I fired up the utility, I only saw the 2015 rev23 image.
Unread 14-01-2016, 21:37
Make sure you've installed the 2016 update and are in the LabVIEW 2015 folder. You should see 2016v19.
Unread 14-01-2016, 21:48
team-4480's Avatar
Debug? What's that?
FRC #4480
I think I might have forgotten to completely unzip the update. I think I stopped because it wanted my password so I put in the same password I used to open the downloader, and it didn't work(the serial number in the KoP).
Unread 14-01-2016, 21:50
The encryption key for the update is the one from the kickoff video: @Ahead)Together!FRC^2016
Unread 14-01-2016, 23:09
FRC #4091
Thanks a million, Klone38 and Mark McLeod!
