Go to Post Better is the enemy of good enough. - petek [more]
Unread 12-01-2016, 02:43
BernieSolo's Avatar
BernieSolo BernieSolo is offline
FRC #1506
BernieSolo is an unknown quantity at this point
Coil Over Shock Absorbers
Hello,
Looking for some advice about using COTS coil-over shocks. These devices usually have oil inside. Would these be a violation of rule R9. Are they considered hazardous or unsafe?
Thank you.
Unread 12-01-2016, 03:09
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Re: Coil Over Shock Absorbers
In the blue box under R9:
G. Hydraulic fluids or hydraulic items
I believe the oil would count as hydraulic fluid.
Maybe you can find an air powered equivalent?
Unread 12-01-2016, 04:25
BernieSolo's Avatar
FRC #1506
Yes, I saw that. And... I also noticed in section 1.4 on page 5:
"Warnings, cautions and notes appear in blue boxes. It is strongly"
"recommended that you pay close attention to their contents as they’re intended to provide insight into the reasoning behind a rule, helpful information on understanding or interpreting a rule, and/or possible “best practices” for use when implementing systems affected by a rule."
"While blue boxes are part of the manual, they do not carry the weight"
"of the actual rule (if there is an inadvertent conflict between a rule and"
"its blue box, the rule supersedes the language in the blue box)."
I hope the Q&A site opens soon.
Thanks for your input.
Unread 12-01-2016, 07:18
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Use air cylinders as the shocks. Use shrader valves in the ports so you can add or remove air from either side of the piston. Instant shock and no spring needed
Unread 12-01-2016, 12:40
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Actually what you would create doing that would be air springs, the "shock" function would be very limited. Not that a robot due to its light weight would really need shocks if it has a spring suspension.
Unread 14-01-2016, 15:43
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Spring suspensions and pneumatic wheels will reduce impact, but cause bouncing. Which might be an issue, or might just be fun to watch
Shock absorbers dampen the bounce. Cars and most motorcycles have springs and shock absorbers.
Here is an excellent video showing the difference between springs and shock absorbers: https://youtu.be/QrQMY8eDDL4
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
Unread 14-01-2016, 16:27
Ryan_Todd's Avatar
Ryan_Todd Ryan_Todd is offline
ye of little faith
Ryan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond reputeRyan_Todd has a reputation beyond repute
Yep, pressurize one side and close that valve completely and you've made a gas spring. Then leave the other outlet open to the air and tighten that valve *most* of the way without closing it completely, and it's a self-contained gas shock/spring combo unit.
Unread 14-01-2016, 21:27
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
You do know that the gas springs that are specifically legal in the rules are partially filled with oil? And that they are dampers (or shock absorbers by another name).
They would act as coil-overs, with the coil spring being replaced with pressurized gas.
Former Mentor Team 1771
Former mentor Team 4509
