Go to Post you, sirs, are most definately gracious proffesionals. - Leav [more]
Unread 14-01-2016, 19:32
AmAlienRobot's Avatar
AmAlienRobot AmAlienRobot is offline
RaiderNation
FRC #3815 (Raider Robotics)
Team Role: Operator
AmAlienRobot can only hope to improve
Exclamation Labview Project, how to start?
Last year we used a My RoboRio project build but this year there is no project called my RoboRio when we go to create project. If you could give us help with this we'd love you 5ever.
Unread 14-01-2016, 21:33
jojoguy10's Avatar
jojoguy10 jojoguy10 is offline
Programming/Controls Mentor
AKA: Joe Kelly
FRC #0997 (Spartan Robotics) and FRC #2990 (Hotwire Robotics)
jojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant futurejojoguy10 has a brilliant future
Re: Labview Project, how to start?
I would suggest looking at the WPI ScreenSteps webpage for a "Getting Started"-type guide. Then, if you have other questions, we'll be ahppy to answer them :-)
http://wpilib.screenstepslive.com/s/4485/m/13811
2013 and 2014 - Student (FRC#2990), Programmer (LabVIEW)
2015 and 2016 - Mentor (FRC#2990), Programming (LabVIEW)
2017-Current - Mentor (FRC#997), Controls/Programming (Java)
2015-Current - A/V Volunteer at Oregon events
Unread 14-01-2016, 21:38
Specifically, you're likely missing the 2016 Update Suite.
Unread 19-01-2016, 16:25
RaiderNation
Team Role: Operator
Angry Re: Labview Project, how to start?
Senior RuffleRidge, we already made the update, but thanks anyways. Other guy complaining about our multiple threads I refuse to apologize for something that was not a mistake nobody responded fast enough.
Unread 19-01-2016, 17:38
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Sometimes just posting a 'bump' in the thread. I watch this folder throughout the day as my job permits. You gave 20 minutes between creating the two threads at 7PM. Guess what I, and probably most other teams are doing at 7PM? Probably meeting with their team! Be patient!
You said you installed the update. When you open LabVIEW, do you see this screen:
http://wpilib.screenstepslive.com/s/...age_id=8030575
If not, then you did not install the update, or it didn't install successfully.
Here's a link to the page where you can get the update: https://decibel.ni.com/content/docs/DOC-46527
Follow the instructions here:
http://wpilib.screenstepslive.com/s/.../13811/c/57243
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 25-01-2016, 17:11
RaiderNation
Team Role: Operator
I actually end up on a different start then what people have been posting
Unread 25-01-2016, 17:17
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
It doesn't look like you have installed the update suite. Perhaps try installing it again?
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 25-01-2016, 17:24
RaiderNation
Team Role: Operator
Okie dokie I'll try again thanks.
Unread 26-01-2016, 16:01
RaiderNation
Team Role: Operator
So I downloaded the stuff at the link that you sent me here: http://www.ni.com/download/labview-f...-15.0/5774/en/
And all that did was download a zipfile, which I couldn't open? Help some more? Much appreciated.
Unread 26-01-2016, 17:15
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Did you use the encryption key in the links that jojoguy10 and RyanN pointed you to.
The encryption key is about one screen down on the
"Installing the FRC 2016 Update Suite (All Languages)" page
READ THE INSTRUCTIONS!
RIght click on the downloaded zip file and select Extract All. If you downloaded the encrypted zip file, you will be prompted for encryption key
Omar
Unread 26-01-2016, 17:23
RyanN's Avatar
RyanN
It's in red text on the page: @Ahead)Together!FRC^2016
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 26-01-2016, 18:58
RaiderNation
Team Role: Operator
So we did the zip file extraction and nothing changed from the first time. Any other suggestions?
Unread 26-01-2016, 19:05
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
did you run the exe in the zip file called setup.exe?
Unread 27-01-2016, 09:03
RyanN's Avatar
RyanN
Did you put in the password?
I seem to remember Windows not handling the password protected ZIP file correctly (Not sure why NI still has a password protected ZIP file being distributed).
I like 7Zip, but WinRAR and WinZip are also good alternatives.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 27-01-2016, 12:15
JeffB JeffB is offline
FRC #5052 (RoboLobos)
JeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to beholdJeffB is a splendid one to behold
The password was removed at some point yesterday. It just hadn't been updated with the non-protected version.
When you try to install, what do each of the screens say? Do any of them say they aren't installing the software? Do they list the software being installed? Does it ask for your S/N? Does it bring up activation at the end?
If you're running into problems, your best bet for this question is likely to give the support team a call at 866-511-6285 between 1-7PM Central.
The others in here are correct. Something isn't going right with the Update Suite installation. That's why you're not seeing the roboRIO project.
