Go to Post Everyone needs to start working with what they are given, and start appreciating FIRST, not complaining about what they think FIRST is doing wrong. - Marygrace [more]
Unread 14-01-2016, 20:43
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
Will 4 8" pneumatic tires work?
One consideration, because of room limits, is for us is to use four 8" pneumatic tires. I think turning via tank drive will be very difficult.
Has anyone tried this?
Would 2 transmissions and four motors be enough to make reasonable turns?
Unread 14-01-2016, 20:45
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Re: Will 4 8" pneumatic tires work?
Based on team Indiana's bot....
https://www.youtube.com/watch?v=7Gt1tazM0ig
Yes. Yes that would work fine.
5349- the RoboEagles
You wanna have a BAD TIME?
Unread 14-01-2016, 20:50
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
It depends on whether you are wide or long. Pneumatic wheels also tend to bounce a little bit so you may need to be wider to turn as smoothly.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 14-01-2016, 20:51
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Note that they were turning on a concrete-like floor.
Turning on 4 wheels, with pneumatic tires on carpet, will be different. Current draw will be a bit higher and you will probably notice some scrubbing.
Edit: Okay, that wasn't the video I thought it was. Was thinking of the other 4WD RI3D bot that was not on carpet. The video linked used a 6 wheel drive. This video used 4WD
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 14-01-2016, 20:52
idahorobot's Avatar
FRC #2130 (Alpha +)
They used six wheels.
Unread 14-01-2016, 21:01
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
It will depend on your track width (distance between parallel wheels) and wheel base (distance between co-linear wheels). The track width should be greater than the wheel base.
If interested this whitepaper goes through the physics of the situation, and provides some general recommendations at the end.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 14-01-2016, 22:43
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
I wouldn't trust our Ri3D robot on carpet. 6 pneumatic wheels with a drop center is highly preferable to a 4 wheel drive for a number of reasons, scrub being one of them. Another reason for 6 would be that it would have an easier time traversing defenses as shown by many of the Ri3D teams.
Unread 14-01-2016, 22:52
kuraikou's Avatar
kuraikou kuraikou is offline
AKA: Alex
FRC #4183 (Bit Buckets)
kuraikou is an unknown quantity at this point
The only way to really know is to build some field elements, assemble a drivetrain and test it. That really is the only way anyone will know if they are going to work or not.
2012 Utah regional Rookie All Star
2013 Phoenix regional Judges Award
2014 Hub City Quality Award
2014 Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award
2015 Arizona East Regional winning alliance captain
Unread 14-01-2016, 22:56
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Or they can reference the Ri3D teams who did build the field elements, assembled the drivetrains, and tested them
Unread 14-01-2016, 23:44
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
+1. We are also planning to paint our wooden defenses with some reasonably glossy paint to try to simulate the steel and aluminum and PVC and polycarbonate surfaces on the actual field. Sprockets and chain are coming from Vex tomorrow for a Saturday build and test session of some rather oversize COTS wheels I bought at Lowes for evaluation based on simulations.
If that works, we'll probably make custom wheels, either in-house using nothing more precise than a drill press, or by CADding and shipping to NASA. Believe it or not, the in-house low-tech solution is my favorite for both technical and aesthetic reasons, not to mention team pride.
To those on the GDC: I LOVE THIS GAME! Non-zero sum (on QP)! Endgame! Weird stuff to do! Flying Boulders! Medieval Language! Real engineering tradeoffs! Even at the end of Saturday, we were still trying to do everything, which was of great "pucker factor" to me and several of our veterans. We've now moved two functions to the back burner, and I'm feeling much better about our chances of actually doing those that remain. BOFFO! (And OBTW, I hope we are figuring correctly!)
Unread 15-01-2016, 13:06
idahorobot's Avatar
FRC #2130 (Alpha +)
Thanks that is obvious I have looked at the three day builds and have built many chassis in the past but none with pneumatic tires. I was hoping to find a team that may have built a 4 wheeled pneumatic machine and could provide an evaluation. Just trying to gather information.
Unread 15-01-2016, 13:14
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
The GreenHorns did build a 4 wheeled drivetrain with pneumatic wheels. I would caution against using just 4 wheels. 6 pneumatic wheels with a drop center is a much better option. The scrub with 4 wheels is significant on carpet.
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
In 2012, 2056 had 8 pneumatic wheels which is essentially a 4 wheel drive base with some raised wheels on the end.
http://www.thebluealliance.com/team/2056/2012
Not exactly what you want but similar.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
