Go to Post what is FIRST?...It's about innovation, hard work, inspiration, teaching, learning, experiment, strategy, competition, meeting new people, being inspired, aiming high and changing paradigms...Really, FIRST is what you make of it. - jarowe [more]
Unread 14-01-2016, 23:41
Crew Cox's Avatar
Crew Cox Crew Cox is offline
Electrical team Captain
FRC #5546 (A.R.T)
Team Role: Driver
Crew Cox is a jewel in the roughCrew Cox is a jewel in the roughCrew Cox is a jewel in the rough
Frame Perimeter when climbing tower?
Hello all,
In regards to the frame perimeter, my team was planning on using a pneumatic cylinder to lift ourselves at the end of the match. The plan is to ascend and then essentially curl the front of our robot upward 90 degrees. However, while hanging, this would put our pneumatic arm over the 15 inch limit for the Frame Perimeter extension. Would this be considered a violation? Or because it is the last 20 seconds of the match would we be okay?
Unread 14-01-2016, 23:54
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Re: Frame Perimeter when climbing tower?
From Official Q & A:
Q. G18 penalizes an extension more than 15" beyond the robot's frame perimeter. Is plane the measurement occurs in relative to the robot or the field? For instance, a robot uses a grappling hook to climb and tilts 90 degrees as it winches itself up. Do you do the same "virtually transposing the robot to a flat floor" as with R22 to determine if the hook extends greater than 15"?
A. Extensions outside the FRAME PERIMETER are measured in the same plane as the FRAME PERIMETER. As the FRAME PERIMETER is re-oriented (e.g. when a ROBOT drives up the BATTER), the plane of measurement is similarly re-oriented.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 15-01-2016, 00:02
Crew Cox's Avatar
FRC #5546 (A.R.T)
Team Role: Driver
Thanks and ouch,
Unread 15-01-2016, 00:48
Ariane Nazemi's Avatar
Ariane Nazemi Ariane Nazemi is offline
Faster than light: no left or right
FRC #5209 (Rectify)
Ariane Nazemi is an unknown quantity at this point
So just to clarify, this means that a robot scaling the tower with its wheels touching the tower wall would have a scaling mechanism that becomes illegal? (Greater than 15 inches)
Unread 15-01-2016, 00:51
Bob Steele's Avatar
AKA: Bob Steele
Correct
Unread 15-01-2016, 01:07
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
This rule is going to be crazy hard to enforce (like the 2013 cylinder rule). Good luck to the referees!
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 15-01-2016, 01:13
Oblarg Oblarg is offline
AKA: Eli Barnett
An interesting observation, relevant to many more varieties of climbers:
Consider a robot positioned on the batter at the base of the tower, which has a mechanism that reaches up to grab the rung.
The batter is, according to the game manual, 6'' tall and 4' deep.
This means that the angle between the batter and the ground is arctan(.5/4).
Accordingly, the angle between the face of the tower and the plane of the robot's frame perimeter, as defined in this rule clarification, is also arctan(.5/4).
The rung is 5'10'' above the top of the batter. A simple calculation:
5'10'' * sin(arctan(.5/4)) = ~8.7''
So, were the frame perimeter flush against the face of the tower, the face of the tower would be 8.7'' outside of the frame perimeter at the height of the rung.
Adding in reasonable bumper thickness, we end up rather close to the 15'' limit. So, if you have a climber that follows the face of the tower up to grab the rung (as we are planning to do), you are safe within this new ruling, but only just. Be cautious of this.
"The breakfast of champions!"
Unread 15-01-2016, 01:14
FRC #5209 (Rectify)
It seems like this rule makes hanging unnecessarily difficult. Teams are going to have a hard enough time hanging in any orientation.
Unread 15-01-2016, 03:46
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Wow. Not only do we have to hang but we have to hang while mantaining bumpers that a te relitively perpendicular to the hanging mechanism? Well I am out. Not worth it. The rules out 99% of hanging solutions that use a cable or rotation enable devices. $5 says that they will changes this in a rule update, due to the the intention of the task. Of course I am not the GDC so I am just speculating.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 15-01-2016, 03:54
mockingod mockingod is offline
VEX 1841, FRC 2090
FRC #2090 (Punahou Robotics)
mockingod is an unknown quantity at this point
Note: I understand that the rule is possible to change.
I showed my teammate this thread and tried to explain it to them and they couldn't really understand what rule you guys were exactly debating so I made crappy cartoon diagram in MS paint that might be useful if you're ever debating with a teammate about this rule for whatever reason.
http://i.imgur.com/SIZCRUt.png
(I don't think the rule is super dumb. I don't think any rules are dumb, rules are rules. I just put that last bit in there for laughs by my team)
Unread 15-01-2016, 06:47
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I like this rule. It's just like climbing in 2013, the cylinder made it tough, then they made that cylinder move with the robot and it got a lot easier. This time the perimeter moving with the robot actually makes it harder. Remember, this is an engineering challenge. If scaling were easy, everyone would do it and nobody would be impressed. But now, it is just complicated enough that you can't just toss a hook up there and winch yourself up. Good work GDC, good work.
To the OP, what combo of cylinders were you planning to use to curl yourself 90 degrees?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 15-01-2016, 08:17
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Here is a quick sketch in CREO showing the minimum distace outside the frame perimeter required to reach the rung. I allowed 3 1/2" for bumpers. The hook must protrude at least 10 inches from the frame perimeter to grab the bar. That gives you a five inch margin.
https://plus.google.com/117322302265...ts/aGrqUdk87dU
Former Mentor Team 1771
Former mentor Team 4509
Unread 15-01-2016, 08:29
FirstUpdatesNow.com
Just to be clear, this is assuming a 36" long robot. If your robot has a shorter wheel base (Which I assume many will), there's more of your robot on the batter and the worse your angle gets. I used 2.5" for my sketch for bumpers for some reason so if you bump my sketch out another inch on the bottom the tolerances are razor thin. Impossible for refs to judge. Terrible Q & A ruling IMO.
@jmontois340
Team 3015
Unread 15-01-2016, 08:36
martin417's Avatar
AKA: Martin Wilson
The length of the robot makes no difference. You also do not need to touch the wall of the tower as in your sketch, just reach over the rung.
Unread 15-01-2016, 08:39
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
The rung you are grabbing onto is not flush with the tower walll. It sticks out, everyone should be well with in the 15 in limit when grabbing the rung. Now how you pull up your robot to stay with in the rules is another matter.
2012-2016 Wave Robotics Team 2826
