Re: Passing the boulder
It seems legal (at the moment!) to hold open the low bar's Cordura flap while in a shooting position. The robot doesn't even have to move between shots. It can be fed from the human player station or with passes from a robot in the neutral zone. I really hope this strategy is clearly ruled out because it seems against the spirit of all the crossing and outer works rules. |
Depending on how you are holding the flap open (perhaps with an extension) you would be violating G40-1. The intent from the Q&A is very clear. ROBOTS have to CROSS the OUTERWORKS controlling the BOULDER, to move the BOULDER into a potential scoring position (touching the COURTYARD carpet). Last edited by bjtheone : 18-01-2016 at 16:22. Reason: typo |
![]() It'd be cool to have trusted moderators to mark posts as obsolete so that stuff that people min-max or brainstorm that becomes illegal can be clearly marked as no longer relevant. |
I think the First made it a Ref'ing nightmare.
With Q603, where the boulder came from makes a difference. Let's say that Red Robot shoots the high goal, and misses. The Boulder rolls and comes to rest in the Outer Works. That boulder is free to be picked up and shot again. Meanwhile, Blue inbounds a boulder, and it is somehow blocked and rolls around in the courtyard. The inbounded boulder is closer to Red Robot, so it goes for that boulder. The Ref's will somehow have to keep track of which Boulders in the Outer Works have successfully crossed, and which ones have not. |
So that BOULDER was never in the NEUTRAL ZONE, correct? Then G40 doesn't apply.
However, that only applies to BOULDERS that did not start in the COURTYARD or SECRET PASSAGE. If Blue inbounds a ball through the BRATTICE or EMBRASURE and Red grabs the BOULDER, G40 does not apply to Red. |
