Go to Post Your students are my idols. - Al Skierkiewicz [more]
Unread 12-01-2016, 12:43
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
Re: Com wire
Originally Posted by RyanN View Post
I just received ours. Item was not as described. I got 50' of green wire with a yellow tracer. Hopefully just a mess-up, but I contacted the seller.
The seller admitted the mistake and is resenting the wire. You should be okay.
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
Unread 12-01-2016, 12:54
Re: Com wire
Originally Posted by kiettyyyy View Post
Make sure your wires have a consistent twist ratio, otherwise, it is possible to have the P and N signals arrive out of phase.
Unread 12-01-2016, 12:59
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Re: Com wire
You want to ensure that both lengths of the positive and negative wires in the differential pair are the same.
It's common practice to ensure you don't have data skew.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 12-01-2016, 13:46
Re: Com wire
Kiet,
At higher data rates that is true. At 1 MPS, the wavelength is approaching 1000 ft. so you would have to fudge the twist by several feet to skew the data.
Unread 12-01-2016, 14:45
kiettyyyy's Avatar
Re: Com wire
Kiet,
Definitely true. I've been working on much higher speed busses for too long
CAN is pretty robust.
-Kiet Chau
www.team1538.com
Unread 14-01-2016, 16:44
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Com wire
The wire and the terminations really do matter, sorry.
The twist of the wires or at least the constant spacing between wires sets the transmission line impedance. The CAN transceivers need the termination resistors to operate correctly. They help set the signalling voltage level and terminate the transmission line. Without them, the reflections at each end of the line allow errors to build up. This is an effect of the length of the line. The longer the line, the worse the effect. Also, the CAN buss should never be parallel wired. In short systems it may seem to work but, as is typical, this system will fail you when you need it the most.
The twisted wiring allows both wires to be exposed to external noise. Since the intruding noise is in phase as it passes through the wire, the twist will cause the 'in phase' noise to be cancelled at the source. Any noise that remains will also be in phase and that will be cancelled at the differential input to the transceiver chip. The twist of 2-3 turns per inch will produce a shunt capacitance of ~20-30pf per foot.
Murphy is always lurking...
Given the length of wiring in FRC robots, reflections are not an issue. Large industrial systems are another matter.
As for twisting and external noise, running the wires together is what allows it to be robust and to cancel out the noise with the differential receiver, not the twisting. The twisting creates an inductance in the line, running the wire in parallel (twisted or not) creates capacitance between the two. The inductance added by the twisting helps to cancel this out.
Unread 14-01-2016, 17:31
Re: Com wire
At 1 MPS, the wire all by itself has inductance. The series inductance and the parallel capacitance sets the line impedance. I use twisted pair shielded cable for a variety of applications, mostly audio. Typical cable has an impedance that is approaching 60 ohms with a parallel capacitance of ~23pf per foot. Ironically, a low impedance transmitter sending into the bus will "see" a 60 ohm load when the bus is terminated at both ends. This is similar to the twisted pair the phone company has used for more than a century. They found that terminating in 600 ohms (about 10 times the actual line impedance) they were able to minimize line loss while getting a flat response if they maintained a source impedance of the same load. I linked a TI CAN document in another thread that shows the waveform distortion with mis-matched loads.
Unread 14-01-2016, 19:15
Sparks333's Avatar
Sparks333 Sparks333 is offline
Robotics Engineer
AKA: Dane B.
FRC #1425 (Wilsonville Robotics)
Sparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of lightSparks333 is a glorious beacon of light
Send a message via AIM to Sparks333
Re: Com wire
Hate to disagree with you, Al, but CAN as a standard is supposed to be a multidrop communications protocol - it's specifically designed to be wired in parallel. In fact, most CAN devices don't have termination built in; they expect termination to be included at either end of the bus. Now for the caveat: I believe the variation of CAN FIRST uses is called Falut-Tolerant CAN, which has terminations at every endpoint, and expects the daisy - chained connection topology implied by the in/out ports of the speed controllers. This means there is a termination at every endpoint, which, when wired in parallel, drastically reduces the overall bus resistance and causes the voltage swing to drop (CAN, like most differential signalling schemes, is current driven instead of voltage level driven). So, while I agree FIRST teams should definitely not connect their devices in parallel, CAN in pretty much any other application is designed to be used as such. Just so none of our bright young minds gets the wrong idea about CAN.
-Sparks
Edit: The Talon SRX manual recommends a parallel linear wiring topology. They're not doing any crazy - just vanilla CAN. Absolutely wire your CAN in parallel
ICs do weird things when voltage is run out of spec.
I love to take things apart. The fact that they work better when I put them back together it just a bonus.
http://www.ravenblack.net/random/surreal.html
Unread 14-01-2016, 19:49
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Re: Com wire
FRC CAN is DW_CAN (aka Dual wire CAN, ISO11898 ).
There are only two termination points, each end of the cable (120ohm).
This means one long transmission line, where each ECU taps in (with a small stub length).
FRC CAN is NOT LSFT-CAN(aka Fault Tolerant CAN, Low Speed Fault Tolerant). Fault-tolerant means something very specific.
The two green wires (Talon) and two green connectors (PCM/PDP) are common. Same is true for yellow. So this produces one long bus-harness that each device taps into (albeit internally, but it is a tap). That's kinda why I never really liked the term daisy-chain, but as far as the person wiring it all, it does all hookup in that fashion, so I'm okay with it.
Sure we could put one single small pigtail on every CTRE CAN Device and force teams to create a bus harness (like in a car) but I think the solution we have now is more robust.
Unread 15-01-2016, 08:19
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
Re: Com wire
Originally Posted by s1900ahon View Post
FRC CAN is 1 Mb/s.
Do you have a source for this? Particarly one that delves into more of the specifics of the FRC CAN protocol?
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 15-01-2016, 08:35
RyanN's Avatar
RyanN
Re: Com wire
http://www.ctr-electronics.com/pcm.h...abs_tech_specs
http://www.ctr-electronics.com/contr...abs_tech_specs
Look at the technical specifications.
More detailed information would be great. I'm thinking of adding a CAN device to the bus, but I'm having trouble getting the timing just right for 1Mbps.
Controls Mentor
@rnazaretian
Previous teams:
Unread 15-01-2016, 09:12
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Com wire
Originally Posted by cpapplefamily View Post
I have searched around for the discussion I'm sure has been touched on many times. Lots of post using phone wire for CAN in the past. My history started last spring so Roborio is my starting point. I would like the team I'm mentoring this winter to start using feed back to operate their robot this year. The off season labs we been preforming has got everyone excited with the possibilities. What I have observed though is many or most of the connection cables we have are pieced together sometimes with two or more solder joints and not always matching colors. I bought a supply of pins and sockets.
Now I'm asking for your experiences would phone and/or Ethernet cable work well for making cables? Solid or stranded? With both types i usually like this strip twice as much wire off and fold it back once to get a solid connection.
A lot of the phone wire usage has stopped with the new CAN interface. Before 2015, the only option for CAN motor controllers, the Jaguar, required you to use phone cable-esque connectors, hence the use of phone wire. Last season, with the new CAN interface used on the Talon SRX, we just used some yellow and green 22AWG stranded core wire, twisted together by hand. The beauty of CAN is that it's not overly sensitive, as long as you have it terminated properly. If you're looking for a way to connect CAN lines together, I suggest these. They are tool-less, easy to use, and they hold well.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 15-01-2016, 09:40
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Com wire
The first documentation in the Crio days suggested regular 6 wire flat phone cable for the canbus. Only two wires is needed for the CAN but the RS232/can converter was in the first Jaguar in the chain so you needed 3 wires for the RS232 to the Crio. (unless you where using the Cross the Road ethernet/can convector) The CAN physical layer standard (CIA 102) allows flat or twisted pairs. Both NI and TI have application papers saying that short stub lengths connecting the devices to the daisy chain is OK. I know a lot of people blamed the com wiring for motor control problems back in the day, but I expect it was more programming issues. The FRC implementation of CAN had a lot of gotchas in it. Not yet mentioned is stranded wire is better than solid from a physical stand point.
So what is my point? The com wiring is pretty forgiving, especially the short length in you typical FRC robot. But if you do right from the start, it is not one the things you have to trouble shoot when having robot problems. You can use flat or twist pairs. My preference is for twisted. You can get away stub lengths that approach what looks like a star configuration. My preference is to keep it flat as possible. You want to avoid running the CANBUS parallel to the motor control wires. You want to securely splice the CANBUS wire together either using connectors or terminals. Loose wires will cause com errors.
Unread 15-01-2016, 11:22
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: Com wire
You mean other than my faint memories?
You can get all of the published documentation, including the protocol documentation:
1. Goto http://www.ti.com/tool/rdk-bdc24-cd, click the 'Get Software' red button, fill out the export regulatory stuff, and download the last distribution.
2. In the Folder, you should find Software > StellarisWare > docs > SW-RDK-BDC24-UG-xxxx.pdf (where xxxx was the last release #).
Section 4.1 contains the partitioning of the 29-bit MessageID. Note that since the most-significant bits of the message contain Device Type and Manufacturer, CTRE can, and probably has, defined their own API. The APIs in that document were for Jaguar.
Unread 17-03-2016, 11:13
JReid JReid is offline
AKA: Jonathan Reid
FRC #5256 (Atomic Vikings)
JReid is an unknown quantity at this point
Re: Com wire
We used a high quality 22 gauge stranded wire that we twisted ourselves, the CTRE CAN connector and crimped ferrules with reasonable strain relief using shrink tubing. Zero problems to date. While the CTRE connectors are a bit unwieldy, the familiarity with the Weidmueller connectors made that choice clear for us.
We used short stubs to the bus per this diagram that I just found which pretty much summarizes all that I learned in the below documentation.
I found several helpful resources just surfing around the internet.
Honestly, the Wikipedia article is pretty good.
One in particular that I really found helpful was Understanding and Using the Controller Area Network by Marco Di Natale posted at berkley.edu It is long, but it references many standards documents and gives a good understanding of how it all works.
If you really want to get your geek on try http://www.can-wiki.info/ which has an excellent network of links.
