Go to Post However, I am a firm believer in the theory that if you are pushing with a mecanum wheeled robot you are doing it wrong. - Andrew Schreiber [more]
Unread 15-01-2016, 10:51
RenanTroia RenanTroia is offline
FRC #1382
RenanTroia is an unknown quantity at this point
Bumper Specifications
Does anyone know If the robot can have a corner shorter than 8 inches? e.g, we are thinking about a robot which has a "u" shape, and the outside corners around that "opening" to the boulder, in our robot, are shorter than 8 in. Is that a violation of the bumper rules?
Unread 15-01-2016, 10:53
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Bumper Specifications
R19 ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER.
For adequate protection, at least 8 in. of BUMPER must be placed on each side of each outside
corner
(see Figure 4-3). If a side is shorter than 8 in., the entire side must be protected by
BUMPER
(see Figure 4-4). A round or circular FRAME PERIMETER, or segment of the frame
perimeter, is considered to have an infinite number of corners.
Unfortunately since the side wouldn't be shorter than 8" it would be illegal.
Unread 15-01-2016, 11:05
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
There are already a few threads on this subject...it's a common idea...the gist of it is that the FRAME PERIMETER is determined by the outer corners, and that's where the bumpers need to be. And they need to extend at least 8" from each externa. corner, towards the next external corner. Not inwards along your U shaped notch.
Unread 15-01-2016, 12:15
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
david.e.boles is on a distinguished road
Seems like you can have sides shorted than 8", not sure about around openings...
http://imgur.com/a/7KjkV
Unread 15-01-2016, 12:17
Flywheel Police
Originally Posted by david.e.boles View Post
Seems like it's allowed to me:
The picture showing the one section with less than 8" is valid because the entirety of that side is less than 8". In a U shaped robot the entire side would not be less than 8".
Unread 15-01-2016, 12:33
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I think of it in this way:
You are not covering the corners of your ROBOT. You are covering the corners of your FRAME PERIMETER. So, Take string and wrap it around your robot. Remove said robot. Wherever there are corners in your string "Frame" you must put 8 inches of bumper on either side of those corners.
Hopefully that helps more then confuses
Unread 15-01-2016, 19:07
GaryVoshol's Avatar
Cogito ergo arbitro
An existing thread on this subject is here: http://www.chiefdelphi.com/forums/sh...d.php?t=141721
It has a picture, and I added my comments about what a "side" of the ROBOT means.
The description by T3_1565 above is also quite good.
(since 2004)
