Go to Post No! I will not be an enabler for this madness. Go outside. See a movie. Read a book. LIVE!!!! - Herodotus [more]
Unread 14-01-2016, 19:41
SupremeSteak1 SupremeSteak1 is offline
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
SupremeSteak1 is an unknown quantity at this point
NetworkTables from GRIP throw an error upon initilization
I have created a GRIP program which identifies reflective tape and have published the network tables. It was when I started to access the tables that I had a problem. I am using the example from the screensteps tutorial, but where I say getTables("GRIP/myContoursReport"), I get the following error: Exception in thread "main" java.lang.UnsatisfiedLinkError: no ntcore in java.library.path. This seems to be unavoidable and I have yet to have any luck fixing it using the VERY few solutions on google. This is the one block to us using GRIP on our robot and it would help greatly. Thanks to anyone who can help, and if anyone needs further information, just ask!
Unread 14-01-2016, 21:36
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: NetworkTables from GRIP throw an error upon initilization
Does NetworkTables work at all, not with GRIP? Try making a new robot project and getting some values from NetworkTables.
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 15-01-2016, 08:34
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
I am testing the NetworkTables in an empty robot project, but there is still no success. To see if it is GRIP would that just be the same thing except instead of "GRIP/myContoursReport", I would put the source of another NetworkTable producing thing? If so, what should I use in its place? Lastly, from what I have seen so far, it is a problem with network tables in general because it seems to be a low down error independent of which NetworkTable is being gotten. Thanks for your help!
Unread 15-01-2016, 08:50
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
What platform are you attempting to run GRIP on? The unsatisfied link error is happening because the jar you're using does not have a native ntcore binary for your current platform.
Unread 15-01-2016, 08:52
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
I am using Windows 10, however come to think of it, this is from the technical preview and I am not sure when the last time I updated was. Could windows 10 be the issue?
Unread 15-01-2016, 09:04
WPILib Developer
FRC #0190
I doubt it, the same ntcore binary works on 7,8,and 10. That being said, you should definitely update to the final version, there's already been a major update to 10 (back in November). How did you install GRIP?
Unread 15-01-2016, 09:50
FRC #0237
Wait, are you running a program on your machine, or on the robot?
Unread 15-01-2016, 11:13
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
On my machine.
Unread 15-01-2016, 11:14
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
Downloaded the executable or installer, can't remember, from their website and clicked next next next.
Unread 15-01-2016, 11:23
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
In the console window before the UnsatisfiedLinkError you should see a line that starts with "platform:", e.g. "platform: /Linux/amd64/". What does it print on your machine?
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 15-01-2016, 14:35
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
I get /Windows/amd64/
Unread 15-01-2016, 15:12
origamitaco origamitaco is offline
FRC #4328
origamitaco is an unknown quantity at this point
That's funny because when I run GRIP on my Windows 10 machine the Driver Station says linux/amd64. I can't even deploy GRIP to the RIO (errors that I can't solve) so it's running on the laptop for now.
Unread 15-01-2016, 16:11
WPILib Developer
That should be correct (for a 64-bit JRE). The next debugging step requires looking inside of the .jar file GRIP is loading to make sure the file is actually there. In C:\Users\<name>\AppData\Local\GRIP\app there should be a "core-1.0.0-all.jar" file. If you rename this to end in .zip, you can look inside it with either WinZip or Windows Explorer (if you didn't know, .jar files are just .zip files under the hood). There should be a Windows\amd64\ntcore.dll file inside... if there isn't, that's the issue (with reinstalling GRIP as the probable solution), if there is, I'm not quite sure what the issue is.
Your robot code will print "platform: Linux/arm" to the Driver Station console because it's running on the roboRio (an ARM platform). GRIP, on the other hand, is running on your Windows machine and will print "Windows/amd64" or "Windows/x86" depending on the JRE. You really shouldn't be seeing "Linux/amd64" anywhere with a Windows / roboRio combination.
Unread 15-01-2016, 16:19
AKA: Thomas Hayden
FRC #1100 (T-Hawks)
I actually just found a solution to the problem. I downloaded the 10th file down and linked it as an external jar in eclipse. It completely solved my problem. Thanks for your help as it also solved some other problems I was having!
Here is the download link for the working NetworkTables.jar: http://first.wpi.edu/FRC/roborio/mav....0.0-SNAPSHOT/
