Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 15-01-2016, 11:06
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Smallest SS Gearbox - COTS or Custom?
I'm trying to fit some gearboxes into our frame and space is very precious at the moment. I was wondering what the most compact way to add a gearbox onto the robot would be. We have some CNC capabilities so making custom gearboxes wouldn't be too bad, but it would be our first time doing so. We're also worried about an 11-72 tooth reduction not holding from the impact loads in this game, so unless there's a great testimonial, I'd rather do dual stage. (Leaning towards single stage but want to make sure it's robust.)
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 15-01-2016, 11:17
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Smallest SS Gearbox - COTS or Custom?
11:72 in one stage is not your problem. Tooth strength is the problem and you can build 12:72 gearsets that will fail on your first crossing and others that will last the whole season with nary a complaint.
What is the face width of the gears involved? What Pitch? What is the size of the wheel you are going to be driving with that 72T gear.
By the way, chain done right can be many many times stronger than gears (largely do to the fact that multiple teeth share the load). Can you fit a stage of #25 chain? 11:72 is fine in one stage of chain (~1"OD to ~5.9"OD)
Dr. Joe J.
Team #88, TJ2
Unread 15-01-2016, 11:26
jkelleyrtp's Avatar
AKA: Jon Kelley
Dr. Joe J.
I'm just poking around at the Vexpro SS. Unfortunately it seems as if a 1:7.52 isn't enough (we're looking for around 10fps with 6" tire)
So perhaps a 14:72 gear reduction then compensate with a 15t to 32t sprocket reduction. Vexpro gears are 1/2" wide with 20DP and a 14.5 pressure angle.
Are you confident this will hold up?
Although I would prefer to do most of the reduction in the gearbox if we were to direct drive any of the wheels.
Mechanical, CAD
Unread 15-01-2016, 11:30
ThaddeusMaximus's Avatar
ThaddeusMaximus ThaddeusMaximus is offline
Thaddeus Hughes
FRC #4213 (MetalCow Robotics)
ThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the roughThaddeusMaximus is a jewel in the rough
Keep in mind: Can you stand to have the output gear that low to the ground? If you're running a 12 tooth cim to a 72 gear direct to a 4" wheel, I would hate to run that because you'd destroy/damage the gear upon going over some of the defenses. For clearance reasons I'd go with a 2 stage. The packaging isn't that much larger if you do it right.
As far as tooth strength goes, the larger the output gear, with equivalent torque, the less force on the teeth. τ = r x F => F=τ/r
Unread 15-01-2016, 11:38
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
The pinions are .5" but remember the gear it's meshing with is only 3/8".
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 15-01-2016, 11:39
jkelleyrtp's Avatar
AKA: Jon Kelley
That's what I was thinking as well... I'm trying to feed it into a 2x1 tube setup and am afraid of actually destroying the gearboxes when going over the defenses. What if we went down the WCP SS style - with enough placement fixing, could we package it ontop of the bellypan or just call it a day and get the Vexpro SS DR at 1:9.52?
Mechanical, CAD
Unread 15-01-2016, 11:58
AKA: Dr. Joe
FRC #0088 (TJ2)
Keep in mind: Can you stand to have the output gear that low to the ground? <snip> I would hate to run that because you'd destroy/damage the gear upon going over some of the defenses. <snip>
Roller Chain for the Win! I'm just saying...
Dr. Joe J.
Team #88, TJ2
Unread 15-01-2016, 13:08
Thaddeus Hughes
Remember that you don't have to direct drive the wheels. I think Joe has the right idea. It might help packaging even more.
Running a dead axle WCD is also a possibility.
