Re: Code won't build
I still don't have much understanding of what you are seeing.
Build will check all of the files, compile them for the ARM/RT situation, and link them into an EXE. It doesn't deploy to the robot. The next step is to right click on the Build Spec and select Run as Startup. If you are still not successful, please give more details as to what you do, what you see, etc. Greg McKaskle |
