Go to Post "The compressor is half the temperature of a toasted Subway sandwich." - Ashley Hartley [more]
Unread 09-01-2016, 18:24
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
FRC KOP 2016 Inventor and STEP
The FRC KOP 2016 should be available on the Autodesk Education website on Monday. For those who want to get started earlier here are links to the KOP in Autodesk Inventor and STEP formats on A360.
http://a360.co/22SRL9w
http://a360.co/1mNCCW2
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 13-01-2016, 21:16
Spark Spark is offline
FRC #5931
Spark is an unknown quantity at this point
Re: FRC KOP 2016 Inventor and STEP
Do you know were i could find a IGES file of the KOP?
Unread 14-01-2016, 14:33
I don't. I create the KOP in Inventor and STEP only.
If you have Inventor 2016 I can walk you through a process using Task Scheduler that will create the IGES files.
Just curious, what are the IGES files for?
Phil Dollan
Autodesk Inc.
Unread 15-01-2016, 15:08
Heburn's Avatar
Heburn Heburn is offline
Computer Jockey
AKA: Espen Storfjell
FRC #2557 (SOTAbots)
Team Role: CAD
Heburn is an unknown quantity at this point
Thanks for posting this ahead of time!
"Can I get an 'Oh Yupp?'"
Unread 21-01-2016, 17:46
JRysenga JRysenga is offline
AKA: Jeff Rysenga
no team (Michigan Engineering Zone (aka "the MEZ"))
JRysenga will become famous soon enoughJRysenga will become famous soon enough
After downloading the Inventor versions I am getting an error when trying to open them.. Database schema for file is.. full error is attached.
Thanks!
Jeff
Unread 21-01-2016, 18:10
Jeff,
Looks like you are using an earlier version of Inventor. Only 2016 can open the Inventor files.
Use the STEP version if you are using an earlier version of Inventor.
Phil Dollan
Autodesk Inc.
Unread 21-01-2016, 18:29
AKA: Jeff Rysenga
Of course! Thanks for the quick reply!
Unread 26-01-2016, 10:33
JOClarke's Avatar
JOClarke JOClarke is offline
AKA: Chainsaw
FRC #0384 (Sparky)
JOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to allJOClarke is a name known to all
Inventor 2016 student addition is continually locking up (not responding), is anybody else having this problem. Can't be hardware running a Dell Precision M4600 8GB Ram I7 quad core 320GB 7200 HD. 32GB Ram on the way & 480 GB SSD but my Dell Precision 2400 seems to run fine using Inventor 2015. Any ideas would greatly be appreciated.
Never stop thinking! It all begins with a spark! Growing up in a FIRST World!
Unread 26-01-2016, 14:47
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Howzit!
My first question would be what graphics chipset do you have installed?
That model can comes with three selections.
• AMD FirePro M5950 Mobility Pro with 1GB GDDR5 dedicated memory
• NVIDIA Quadro 1000M with 2GB GDDR3 dedicated memory
• NVIDIA Quadro 2000M with 2GB GDDR3 dedicated memory
CAD is heavy on graphics. I normally would not suggest heavy CAD on a laptop unless it has a real good graphics chipset with lots of dedicated memory.
Also some additional information could be helpful. Like operating system you are using. Clock speed of processor.
You can check your system specs and compare them to the Inventor requirements at
https://knowledge.autodesk.com/suppo...-products.html
Good luck this year!
Aloha
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
