Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 15-01-2016, 14:45
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
Cleated Tread
Has anyone used this cleated conveyor belting material from McMaster-Carr as tread on a Plaction-type wheel before? What was your experience?
http://www.mcmaster.com/#5987k1/=10p0j32
(Follow up question - how much do we trust plaction wheels when jumping over the moat? We're running out of 8" wheel options
Unread 15-01-2016, 14:56
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
Re: Cleated Tread
Out of curiosity, why do you want to use something like this instead of any of the "regular" plaction wheel treads? I don't really see any benefit or advantage over a standard roughtop plaction wheel.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 15-01-2016, 15:11
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Cleated Tread
I seem to think "cleats" are against the rules. Check out R6.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 15-01-2016, 15:16
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: Cleated Tread
I would be surprised if this belt material contravened R6. It's just aggressively cut rubber, and unlikely to damage the carpet. No worse than versawheels for sure.
I would be shocked if no one in FRC has tried this stuff before.
Unread 15-01-2016, 15:28
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Re: Cleated Tread
should have looked at the description before commenting.
If the "tread" were facing out then you'd be driving the smooth backing, which might slip.
Unread 15-01-2016, 15:30
CryptoStorm's Avatar
CryptoStorm CryptoStorm is offline
EIC Tech
AKA: Joshua Stilwell
FRC #5056 (MegaHurtz)
CryptoStorm is an unknown quantity at this point
Re: Cleated Tread
I don't think you would have an issue. I used conveyor belt on one of our previous robots (2006 I believe). the issue you might run into is stitching the conveyor belt together at the ends. In industry this is typically done with a crimp on 'lace' with a stainless wire used as the pin.
http://images.drillspot.com/pimages/...359590_300.jpg
Unread 15-01-2016, 15:37
EIC Tech
Re: Cleated Tread
I would guarantee that this stuff was actually conveyor belt long before it was wheel traction material.
http://www.simbotics.org/sites/all/t...lity-ben-1.png
Unread 15-01-2016, 16:17
Re: Cleated Tread
The "cleats" on that material are only 1/8" tall and are made out of the same soft material as the rest of the belt.
Compare that to http://www.andymark.com/product-p/am-0940a_blk.htm
Unread 15-01-2016, 16:54
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Cleated Tread
Plaction wheels will not survive slamming into things like that. The thin lip they use to secure the tread side-to-side will fracture and break off. We have extensive experience with plaction wheels. In fact, just popping wheelies and coming down hard will cause the same failure mode. Versa's version are more durable in that regard.
As a temporary fix to the lip coming off, you can rivet all along the thread in between each spoke. Eventually, however, the rim itself will fracture through at one of these points.
Unread 16-01-2016, 08:49
AKA: Brendan Simons
FRC #5406 (Celt-X)
Re: Cleated Tread
Thanks. That's good, and disappointing feedback
Unread 16-01-2016, 11:12
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: Cleated Tread
Team 234 used a similar style of tread in 2004 and 2006.
The stuff was almost literally bullet proof and quite heavy.
Biggest issues (with any belt drive) are keeping tension on the drive sprocket, belt tracking and alignment, and creating a "low point" around which the robot will turn.
Collin Fultz
