Go to Post what is integration if not a compromise? - Kris Verdeyen [more]
Unread 14-01-2016, 23:50
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Robot Radio 12V, Increased Brownout Risk?
Not sure if this has been discussed on CD already, if so I apologize.
This year our new compact robot radio has a DC voltage rating of 12-18 V. Also, so far in my experience it takes up to twice as long to initialize as the former routers.
I analyzed the voltage levels from our 2015 matches and did notice several instances where we dropped below 10.5 volts during a match even with good batteries.
Has anyone experimented with the radio yet to see at what voltage the router would shut down/reboot, or if there are any symptoms of a reduced voltage during a match (reduced range, or maybe the router goes into a safe mode that reduces capability temporarily?).
I'm getting increasingly nervous that a powerful drive system we are designing will kill our radio during a match.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 14-01-2016, 23:54
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Robot Radio 12V, Increased Brownout Risk?
Power to the radio should be taken from the Cross the Road Electronics Voltage Regulator 12 V 2 A rail, Per R43, which will maintain voltage below what the RoboRio browns out at.
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
From what I understand, The VRM has a separate converter for the radio board and keeps the voltage steady at 12V even if the battery voltage drops significantly below 12 V
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-01-2016, 23:56
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
The radio is required to be plugged into a Voltage Regulator Module, which functions down to 5 volts per its specifications.
Unread 14-01-2016, 23:57
seg9585's Avatar
AKA: Eric
Yes of course, but I didn't realize the VRM can maintain 12V if it's input voltage was lower than 12V?
It's a regulator, is it also a transformer??
My FIRST legacy:
Unread 15-01-2016, 00:06
Jacob Bendicksen's Avatar
Jacob Bendicksen Jacob Bendicksen is offline
Figuring out what's next
Jacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond reputeJacob Bendicksen has a reputation beyond repute
Transformers only work for AC, and FRC control systems run on DC. However, you're essentially correct in that the VRM functions as a bi-directional level shifter in order to provide a constant 12V supply.
jacobbendicksen.com | @jacobbendicksen
Yale University Class of 2020
Team 1540 | 2012-2016
7 Chairman's Awards, 6 other awards, 2015 Dean's List Finalist, 1 event win, 2 finalist finishes. Thanks for an amazing ride.
Unread 15-01-2016, 00:08
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I think it is a kind of "Boost Buck Converter" that steps up or steps down the DC voltage as needed.
They're a cool piece of tech.
Dr. Joe J.
Team #88, TJ2
Unread 15-01-2016, 01:15
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
We used the new Robot Radio on 'Snow Problem. We did not encounter any brownout issues, just a few setup issues.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 15-01-2016, 01:19
JohnFogarty's Avatar
AKA: @doctorfogarty
We used the new radio on Team Cockamamie with no setup or brownout issues.
John Fogarty
Unread 15-01-2016, 15:45
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Operation is completely transparent after the setup issues?
Unread 15-01-2016, 15:52
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
We've had some interesting connection problems, however I'm not entirely convinced it's on the radio's end (quick fix involves taking down the wireless card on the laptop). Our radio also is not from a KOP, so we ended up having to follow these instructions to update it manually. It's possible that the firmware which shipped on the radio in the KOP and the firmware listed in that file are different.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
