Go to Post Someone Photoshopping Heidi...............now there's a switch! - Jay H 237 [more]
Unread 15-01-2016, 15:56
nathanv's Avatar
nathanv nathanv is offline
nathanv
AKA: Nathan Vaniman
FRC #4984 (Bullseye)
nathanv is an unknown quantity at this point
RobotBuilder does not work
If I try to export my RobotBuilder project to C++, I only end up with some of the files that I should have and Robotbuilder gets stuck loading. Any ideas what this could be?
Unread 15-01-2016, 19:42
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
AKA: Sam Carlberg
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: RobotBuilder does not work
Can you be more specific? What files aren't being generated?
WPILib
GRIP, RobotBuilder
Unread 15-01-2016, 20:45
nathanv's Avatar
nathanv
AKA: Nathan Vaniman
The files in the subsystem folder
Unread 15-01-2016, 21:12
nollchr nollchr is offline
nollchr is an unknown quantity at this point
I just updated to the latest plugins and the robot builder is erasing all my custom public function implementations when I re-export and the code is clearly NOT between the //begin //end autogen comments!! Only seems to happen in the .cpp. The declarations in the header don't get erased.
Unfortunately, I can't confirm if this was happening with the plugin that was release prior..
Unread 15-01-2016, 23:55
Yes, it happened with the previous release. See https://usfirst.collab.net/sf/go/artf4796
Unread 16-01-2016, 08:25
sigh..thanks for the info...seems like something that should be fixed soon hopefully...that's a pretty significant bug
Unread 19-01-2016, 14:44
powster powster is offline
FRC #1148
powster is an unknown quantity at this point
Yeah, Robot builder hasn't been working for me either. The projects generated with it cannot build and are missing the Debug and Include files that are made when you make a sample WPILIB Robot project. Also, it does not edit file and only keeps creating them when I make modifications as well.
