Go to Post Your body does not have replacement parts. - Koko Ed [more]
Unread 15-01-2016, 15:52
JoelRummel JoelRummel is offline
FRC #4855
JoelRummel is an unknown quantity at this point
Defining/Setting a motor in Java
I am trying to run a VERY SIMPLE piece of Java.
Its only goal is to set a motor's speed to 0.5.
Yet I have difficulties with even this simple task:
package org.usfirst.frc.team4855.robot;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Talon;
public class Robot extends IterativeRobot {
	Talon talonMotor;
    public void robotInit() {
    	talonMotor = new Talon(0);
    public void teleopInit(){
    	talonMotor.set(0.5);
Not only does this not work but I get a whole bunch of crap in the driver station:
ERROR Unhandled exception: java.lang.RuntimeException: Code: -1029. HAL: Resource already allocated at [edu.wpi.first.wpilibj.hal.PWMJNI.allocatePWMChanne l(Native Method), edu.wpi.first.wpilibj.PWM.initPWM(PWM.java:117), edu.wpi.first.wpilibj.PWM.<init>(PWM.java:134), edu.wpi.first.wpilibj.SafePWM.<init>(SafePWM.java: 35), edu.wpi.first.wpilibj.Talon.<init>(Talon.java:51), org.usfirst.frc.team4855.robot.Robot.robotInit(Rob ot.java:31), edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:72), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:241)]
WARNING: Robots don't quit!
Give it enough time and the robot will just reach an emergency stopped state without any apparent reason.
What in the world am I doing wrong
Unread 15-01-2016, 16:11
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Re: Defining/Setting a motor in Java
First, the 50% code should be in teleopPeriodic, not init (so it keeps getting called over and over again).
Second, you're creating the talon at least twice. Your code isn't complete so I can't see where else it's being constructed.
All opinions are my own.
Unread 15-01-2016, 16:18
FRC #4855
Thanks, put the code in teleopPeriodic.
I'm confused with your second point. The code I posted is all the code there is.
Unread 15-01-2016, 17:37
iSpotix iSpotix is offline
FRC #4049
iSpotix is an unknown quantity at this point
I have always written it in one line directly under the class statement not in robotinit.
Talon motor = new Talon(0);
Your problem may be from splitting it up.
Unread 15-01-2016, 17:41
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
That shouldn't cause it, his motor reference would just be null prior to calling robotInit().
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 16-01-2016, 00:24
AKA: Joel Gallant
The error stack shows Robot.java:31, meaning line 31. You don't have 31 lines posted in your thread.
And you're missing a curly brace to close the class. The above by itself wouldn't compile.
Unread 16-01-2016, 10:40
FRC #4855
That's because I had a bunch of blank space and comments that I got rid of when I copied and pasted the code here
I'm no longer getting errors in the console after moving to teleopPeriodic. But the motors still won't move.
I checked the motors earlier by hooking them up to our battery. They work fine...
Unread 16-01-2016, 11:16
pastelpony's Avatar
pastelpony pastelpony is offline
Programmer/Electrical
AKA: Zach M
FRC #3525 (Nuts and Bolts of Fury)
pastelpony will become famous soon enough
I am having the same issue. I am trying to execute EXTREMELY basic code (operating a Victor). Yet, whenever I try to execute the code, nothing happens and my console gives no hints. Even the sample code does nothing to the robot right now. It successfully deploys yet does nothing.
Team 3525 Head Programmer (2014- ) - Java (Formerly LabVIEW)
Unread 16-01-2016, 11:45
FRC #4855
Nevermind. It was a stupid electrical error. I thought I had checked the system thoroughly but apparently I hadn't.
Thanks for letting me know it wasn't the code's fault.
Unread 16-01-2016, 12:17
AKA: Joel Gallant
Always is
