Go to Post I'll admit that the events at Epcot were pretty nice, but they too had their problems. . . You were at the mercy of the weather, and Disney hasn't figured out how to control that yet. - Kevin Sevcik [more]
Unread 15-01-2016, 15:28
nxtmonkeys's Avatar
nxtmonkeys nxtmonkeys is offline
SCP-682
AKA: Parker Wells
FRC #5349 (RoboEagles)
nxtmonkeys will become famous soon enough
Modded Kitbot
So, we're thinking of using the standard wide config for the wheelbase, but with extra wheels offset higher in the front. What do you all think? 2 CIMs per side...
Geez, that's a huge picture.
5349- the RoboEagles
You wanna have a BAD TIME?
Unread 15-01-2016, 15:32
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Modded Kitbot
What's wrong with just the wide config? The one you have will make bumper mounting more difficult and prevent you from having a chassis cutout in the front.
Unread 15-01-2016, 15:40
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Re: Modded Kitbot
Thanks for the input!
We're planning to have a bumper higher up, and hopefully will have a chassis cutout in the front by using more support farther back...
Unread 15-01-2016, 16:26
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Re: Modded Kitbot
Show me where you're going to put the bumpers.
Unread 15-01-2016, 16:33
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Re: Modded Kitbot
http://i.imgur.com/A6EzWob.png
Unread 15-01-2016, 16:35
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Re: Modded Kitbot
Originally Posted by nxtmonkeys View Post
So they would pass in front of the wheels on the front?
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Re: Modded Kitbot
In front of the wheels, but not below them. So, Yes.
S' gonna be a pain to build.
Unread 15-01-2016, 18:34
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Modded Kitbot
I hope you put in "stepped up" bumpers that way because it was easy to draw. You can't do it in real life. A BUMPER doesn't have to be level, but it does have to be 5" top to bottom at all points.
Your FRAME PERIMETER is somewhere in front of the tilted up wheel (what ever structure you have in front of it). So you'd need a BUMPER on that section, and it must be in the BUMPER ZONE - 4 to 12" off the floor. Since the BUMPER is 5" in height, the most ground clearance you can get in front is 7" (12 - 5).
Your side BUMPER also has to extend all the way to the front, so it will protect the front corners.
(since 2004)
Unread 15-01-2016, 20:15
nxtmonkeys's Avatar
SCP-682
AKA: Parker Wells
Red face Re: Modded Kitbot
Thanks! We'll make sure to adhere to all o' the bumper rules.
Unread 15-01-2016, 20:33
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
This looks like a bad idea. Sorry but it does.
Unread 15-01-2016, 21:58
bstew's Avatar
bstew bstew is offline
FRC #3928 (Team Neutrino)
Team Role: CAD
Rookie Year: 2015
bstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to beholdbstew is a splendid one to behold
Re: Modded Kitbot
Do you care to explain why? What evidence do you have or are you just judging off of looks?
Unread 15-01-2016, 22:07
Sperkowsky's Avatar
As a CAD guy this is a nightmare. Bumpers are going to be insanely difficult, and manufacturing this out of a kit chassis while. Maintaining the necessary strength around the high impact joint is going to next to impossible. If someone showed a similar design as custom CAD that was going to be precision machined it would be one thing but if your team is using a kit chassis (my team uses one as well for context) then this sort of design is just too complex.
Not to mention the benefits are minimal. Your wheels Will not be the first thing to contact obstacles because of the front plate and the Cog is going to be off.
Just my Opinion
Unread 15-01-2016, 22:20
bstew's Avatar
Team Role: CAD
Rookie Year: 2015
Re: Modded Kitbot
Thanks for your explanation. I see what you mean with the bumpers, but wouldn't that effectively be the same challenge as with the AM Rhino Tracks. While I am not sure this is the best way to cross the defenses, it would certainly be an interesting challenge.
(BTW, I am a CAD guy too)
Unread 15-01-2016, 22:31
Sperkowsky's Avatar
I never said the rhinos were going to make bumper making easier either. There was a cad competition a few weeks ago on here and I decided to try out the rhino tracks. Spent an hour trying to get legal corner bumpers on there.
I think you better off doing something simpler like a wedge on the front (check Andymarks new video). Switching to pneumatic wheels/bigger wheels or putting some type of puller mechanism on the front.
Although this definitely is a cool challenge. I just don't always like cool challenges during the challenge of build season.
Unread 16-01-2016, 06:38
inorbert inorbert is offline
Build Captain and Driver
FRC #5811 (BONDS)
Team Role: Driver
Rookie Year: 2016
inorbert is an unknown quantity at this point
Use large wheels in back and a smalley one in front, works relatively the same
