Go to Post I've learned never to say never when it comes to FIRST teams. - Karthik [more]
Unread 15-01-2016, 17:41
dieDoktor dieDoktor is offline
AKA: Kipling Cohen
FRC #4118 (Roaring Riptides)
dieDoktor is an unknown quantity at this point
Re: Ramparts
22tan(8deg)= 3.092
So... roughly 3.1 inches
Unread 15-01-2016, 19:25
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Ramparts
Originally Posted by dieDoktor View Post
22tan(8deg)= 3.092
That's what I got when I did the math on Saturday. Note that the robot does not need quite this much ground clearance to get on top of the rampart, because it is running up the ramp; this is similar to the front clearance needing to be less than 15" to get under the 16" low bar. Just how much is needed is a function of your wheelbase and how far your chassis extends ahead of the front wheel axle.
While we're designing with enough ground clearance to cross the ramparts on-center, we'll probably make our robot narrow enough to drive up the left side, and only have to worry about the steep drop on exiting.
