Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 12-01-2016, 09:50
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Team Drawing Field BOM?
Has anyone found a BOM for the parts/wood needed to build the field? If not how much woods if you purchase to build the field?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 12-01-2016, 11:38
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: Team Drawing Field BOM?
You can find the official team version drawings of the field elements in the file titled "2016TeamVersions" in this zipped folder: https://firstfrc.blob.core.windows.n...wings-2016.zip
I went through that document last night to make a listing of how much of material each field element would require, and how many of each field elements you would need to have a full field*:
*It was a late night, so please feel free to make any corrections
(2 x) Human Player Station – 1 sheet of 1/2" plywood, 1 2x4
1/2" Plywood (15/32”)
(1 x) 12” x 15.31”
(2 x) 12” x 15.31”
(2 x) 11.53” x 15.31”
(2 x) 15.31” x 12.94”
(1 x) 10.50” x 10.50”
(2 x) 16” x 68”
(1 x) 11.44” x 10.50”
2x4 Lumber
(2 x) 48”
(2 x) Tower – 3 sheets of 1/2" plywood, 11 2x4’s
(1 x) 48” x 21”
(1 x) 24” x 36”
(2 x) 24” x 36”
(3 x) 30” x 30”
2x4 Lumber
(1 x) 56”
(3 x) 21”
(3 x) 23.44”
(6 x) 111.25”
(6 x) 24.29”
(6 x) 29.49”
(6 x) Hanging Bar – 2 sheets of 1/2"plywood, 8 2x4’s, 1 1.5” Dia. Wooden Dowel
(2 x) 32.50” x 32.50”
(1 x) 24” x 72.50”
(1 x) 24” x 44.50”
(2 x) 39.91” x 5.53”
(1 x) 11” x 24”
2x4 Lumber
(2 x) 72”
(2 x) 72.50”
(2 x) 86”
(2 x) 21”
(4 x) 20.06”
(1 x) 27”
(10 x) Defense Platform – 1 sheet of 3/4" plywood, 1 sheet of 1/2" plywood, 2 (3) 2x4’s
3/4" Plywood (23/32”)
(1 x) 24” x 48”
(2 x) 10” x 48”
2x4 Lumber
(4 x) 24”
(2 x) 48”
Cheval De Frise – 1 sheet of 3/4" plywood, 1 sheet of 1/2" plywood, 1 2x4, 1.25” Dia Black Iron Pipe, plus Miscellaneous
(1 x) 23.750” x 48”
(2 x) 11.75” x 23.75”
2x4 Lumber
(4 x) 3.88”
(4 x) 11”
1.25” Dia. Black Iron Pipe (1.38” inner, 1.66” outer)
(1 x) 48”
Miscellaneous
(8 x) pipe clamp, cheval de fries
(16 x) flat head screw, 3/8-16 x 1.25”
(16 x) nut, nylock 3/8-16
(2 x) Low Bar – 1 sheet of 3/4" plywood, 1 2x4, Black Iron Pipe, Cordura Fabric
(1 x) 23.750” x 48”
2x4 Lumber
(2 x) 18”
1” Dia. Black Iron Pipe (1.05 inner, 1.32” outer)
(1 x) 42”
(1 x) 48”
Cordura Fabric
(1 x) 44” x 25”
Sally Port – 1 sheet of 3/4" plywood, 1 sheet of 1/2" plywood, 2 2x4’s, plus Miscellaneous
(1 x) 23.75” x 48”
(2 x) 15” x 25”
(1 x) 24” x 48”
2x4 Lumber
(2 x) 10”
(3 x) 25”
(2 x) 12”
Miscellaneous
(3 x) Mortise-Mount Hinge
(1 x) Wright Storm Door Closer, V1020BL
Drawbridge – 1 sheet of 3/4" plywood, 2 sheets of 1/2" plywood, 6 2x4’s, plus Miscellaneous
(1 x) 23.75” x 48”
(1 x) 42” x 8”
(1 x) 36” x 46”
(2 x) 23.75” x 60”
2x4 Lumber
(4 x) 60”
(2 x) 42”
(4 x) 16.75”
(2 x) 16.75”
2x2 Lumber
(2 x) 6”
Miscellaneous
(4 x) nut, nylock 1/4-20
(8 x) 1/4"-20 Washer
(4 x) eye bolt, 1/4-20 x 2”
(4 x) Door Hinge
(2 x) Spring and Threaded Connector
Ramparts – 2 sheets of 3/4" plywood
(1 x) 48” x 24”
(2 x) 24” x 2.28”
(2x) 21.50” x 24”
Rough Terrain – 1 sheet of 3/4" plywood, 1 4x4
(1 x) 23.75” x 48”
4x4 Lumber
(10 x) 1”
(10) 3”
(11 x) 2”
Moat – 1 sheet of 3/4" plywood, 2 2x4’s
(1 x) 23.75” x 48”
2x4 Lumber
(2 x) 48”
Rock Wall – 1 sheet of 3/4" plywood
(1 x) 23.75” x 48”
(2 x) 3.91” x 48”
(1 x) 4.50” x 48”
(5 x) 3.91” x 3.06”
Portcullis – 1 sheet of 3/4" plywood, 1 sheet of 1/2" plywood, 4 2x4”s
(1 x) 24” x 48”
(2 x) 1.94” x 5”
(1 x) 32.25” x 47”
(2 x) 7.75” x 72”
(2 x) 47.50” x 15.13”
2x4 Lumber
(4 x) 72”
(6 x) Batter Part 1 – 1 sheet of 1/2" plywood
(2 x) 37” x 5.50”
(1 x) 43.87” x 23.88”
(1 x) 5.44” x 22.88”
(4 x) Batter Part 2 – 1 sheet of 1/2" plywood
(1 x) 37.55” x 43.79”
(2 x) 5.30” x 36.38”
(1 x) 36.38” x 8.63”
2x4 Lumber
(2 x) 12”
(2 x) Batter Ramp, Half Corner Part 1 – 1 sheet of 1/2" plywood
(1 x) 21.75” 38.15”
(1 x) 35.39” x 5.08”
(1 x) 30.73” x 5.16”
(2 x) Batter Ramp, Half Corner Part 2
(1 x) 21.75” 38.15”
Unread 12-01-2016, 12:03
IronMustang9's Avatar
IronMustang9 IronMustang9 is offline
FRC #3711 (Iron Mustang)
Rookie Year: 2016
IronMustang9 is an unknown quantity at this point
Thumbs up Re: Team Drawing Field BOM?
Thanks for putting this list together!
Unread 12-01-2016, 12:21
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Has anyone found the specifications for the Drawbridge "Spring and Threaded Connector"?
Unread 12-01-2016, 14:24
msonnier msonnier is offline
Engineering Mentor
FRC #2992 (SS Prometheus)
msonnier is an unknown quantity at this point
I'm pretty sure your quantities of pipe clamps, bolts and nuts for Cheval de Frise are wrong.
There are 4 teetering platforms, each of which needs 2 pipe clamps and each pipe clamp needs 2 bolts and nuts.
Therefore under miscellaneous for CdF I think it should be:
Thanks for putting this list together.
Unread 12-01-2016, 14:26
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
It looks like you're right, I had only accounted for two of the platforms. Thanks for the correction! I have edited my original post to fix this.
Unread 14-01-2016, 09:41
JV_Mentor_1306 JV_Mentor_1306 is offline
FRC #1306
JV_Mentor_1306 is an unknown quantity at this point
From competition drawings :
HW-00099 : Extension Screen Door Spring, 15"-18 1/2"
HW-00100 : Screen Door Spring, 16-3/8" Long
For each : 2 Oval Threaded Connectors, 3/16" Diam
Unread 14-01-2016, 13:45
ironhawk ironhawk is offline
Team Mom
AKA: Juliet
FRC #2265 (FeMaidens)
ironhawk is an unknown quantity at this point
Thank you so much for putting this together - I started looking through the field components and almost immediately got a (figurative) headache. You're wonderful!
Unread 14-01-2016, 14:00
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
We are building the Chin-up bar with two ramp corners (1&&2). Then Put a low goal door in it. Then a opening at the top to simulate the High Goal. Kills the whole tower in one device.
Then a Outer reach receptacle to insert the obstacles we are choosing to focus on.
Unread 14-01-2016, 15:42
mcmission mcmission is offline
FRC #2052 (KnightKrawler)
Team Role: Parent
mcmission is an unknown quantity at this point
Here is a link to assist with BOM - our team already has field side walls and the driver stations built from previous years so they are not included. Also, this plans for only one of the 8 defense elements for the field. You may want to build two of each. Estimated sheet totals of plywood and 2X4s are in green cells. We also use OSB for some vertical walls on some elements.
https://drive.google.com/open?id=0B6...HpPRDI3U21XeUk
Unread 14-01-2016, 18:23
Ghostbot747's Avatar
Ghostbot747 Ghostbot747 is offline
FRC #3189
Ghostbot747 is an unknown quantity at this point
Has anyone else noticed the difference in the angle of the defense ramp. C.A.D. Files say 14.5 manual says 13.5
Unread 15-01-2016, 18:24
Beta+ Beta+ is offline
FRC #2130 (Alpha+)
Rookie Year: 2015
Beta+ is an unknown quantity at this point
I just noticed this also - the length of the ramp is different as well. Section 2, page 10 of the Game manual diagram shows ramps at 1 ft long and 13.5 degrees, while the CAD Team Defense Platform drawing has a 10 inch ramp onto a 75.5 degree bevel resulting in a 14.5 degree angle.
We're really interested in our angle of attack for the low bar, so quick clarification would be appreciated.
Unread 16-01-2016, 04:46
Trevor Harris Trevor Harris is offline
FRC #0034 (The Rockets)
Team Role: CAD
Trevor Harris is an unknown quantity at this point
[quote=JV_Mentor_1306;1523434]From competition drawings :
Can anyone explain the need for two different springs on the drawbridge?
Unread 18-01-2016, 10:46
Ubiquity Ubiquity is offline
FRC #5027
Ubiquity is an unknown quantity at this point
On the sally port, the plan says 3 25" 2 by 4s, put I only see two used in the construction.
Also the 4 ft 2 by 4 18 degree angle cut can be tricky. Really needs a table saw and someone who knows how to do it safely.
Former mentor: 255(4y), 254(2y), 668(1y), 751(1y),5027
Current mentor 2854, 5905
Volunteer, Ref, Inspector, Judge, FTA
Nat. Champion 2000(255), Nat. Chairman's 2004(254), SVR Champion 2015(5027)
(Botball N. Champ 2001)
Unread 26-01-2016, 22:07
TOTCoach's Avatar
TOTCoach TOTCoach is offline
That ONE Coach
AKA: Dan Hartley
FRC #4967 (That ONE Team - Our Next Engineers)
TOTCoach is an unknown quantity at this point
We built the Sally Port tonight and noodled over the 3 25" 2X4s, and found the first page materials list only lists 2 of those, but the dimensiond drawings indicate 3. You only need 2.
However, we also found that the door is so heavy on the short little wall, it is pulling it over. Will reinforce with brackets and possibly lighter weight door.
4967 - Rookie season 2014
Gull Lake: Rookie All Star, Highest rookie seed (#2), Winner (Thank you 2054 & 5248)
West Michigan: Rookie Inspiration, Highest rookie seed (#4)
Michigan Championship: Rookie All Star, Highest rookie seed (#17)
Galileo Division: Rookie Inspiration, Highest rookie seed (#16)
Our students all learned so much, Thank you FIRST for the Inspiration!
ThatONEteam.org
