Go to Post ... hey which end of the robot faces the wall anyways? Oops.... :rolleyes: - dhitchco [more]
View Poll Results: Will your robot have the capability to load directly from brattice?
Yes 8 17.78%
No 37 82.22%
Voters: 45. You may not vote on this poll
Unread 15-01-2016, 19:16
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: loading directly from brattice
With the limited number of boulders (not like RCs or AA balls, but far from unlimited), any robot that plans to move and/or score boulders needs a ground pickup anyway, and you have to drive farther to use the brattice, so why do a second loader? Actually, there is a possibility that our low-bar-capable robot will be able to load from the brattice without the ball hitting the carpet, but it's not a design requirement. We will probably not even build a brattice for our own practice, though we may if we can figure out how to do a half-court scrimmage.
