Go to Post And Dave, although I know you have connections, please don't slow the earth's rotation to get more time on the caption contest. ;) - Billfred [more]
Unread 14-01-2016, 23:33
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Cannot get FRC plugins to appear in Eclispe Mars on Windows
This is in Eclipse, version Mars, on Windows.
I cannot get the FRC plugins to "work". For example under New,Project, the selection for "WPILib Robot ++Development" does not appear. Also under Window, Preferences, "WPILib Preferences" is missing.
I tried reinstalling the FRC plugins, removing them from under "Help, Installed Software" and rebooting the machine. Still nothing from the plugins.
I do have the FRC toolchain installed and existing projects build, just can't create new ones.
Also, I noticed that when performing a "Clean" on a project, I see this in the output window:
Cannot run program "rm": Launching failed
The project does get cleaned successfully though, the debug folder is removed. Is Eclipse just always issuing the rm command which of course exists on Mac and Linux, but not Windows?
I went back to the Luna version of Eclipse, and updated the plugins and all is working again.
Thanks,
Brian
Brian K
Team 1225 Robotics Mentor
Unread 15-01-2016, 20:59
SamcFuchs's Avatar
SamcFuchs SamcFuchs is offline
Programmer
AKA: Sam Fuchs
FRC #0236 (TechnoTicks)
SamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud ofSamcFuchs has much to be proud of
Re: Cannot get FRC plugins to appear in Eclispe Mars on Windows
I got it working on Win10 with no problems. Have you tried it on a different machine?
Unread 24-01-2016, 23:54
SuperBK's Avatar
AKA: BrianK
To solve the problem, I had to start with a new clean copy of Eclipse. I had previously updated Eclipse in place over an older version. With a new install and plugins, everything worked.
Brian K
