Go to Post when answering a question you throw out other teams names (thunder chickens and killer bees)...and a distinguished guest raises his hand and asks if he heard right when I said thunder chickens and asks for an explanation of what a thunder chicken is. - Devon27 [more]
Unread 15-01-2016, 21:08
feoniks4505 feoniks4505 is offline
FRC #4505 (MECHDonogh Eagles)
feoniks4505 is an unknown quantity at this point
Encoder Issues
Hey, so we are trying to hook up our encoders, and we have them working while they are hooked up to the Roborio, but we don't get any values while we are hooked up to our CAN Talon. We've checked several diagrams and our wiring, and those don't appear to be the issue. Any help you could supply would be greatly appreciated. Thanks!
Unread 15-01-2016, 21:11
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Encoder Issues
Whenever you have a problem it is ALWAYS helpful to post code that goes with it.
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 16-01-2016, 12:27
Re: Encoder Issues
Here is our execute method in our sensor-reading command:
protected void execute() {
    	SmartDashboard.putNumber("Encoder Raw", Robot.sensors.getRaw());
    	SmartDashboard.putNumber("Encoder Rate", Robot.sensors.getRate());
    	SmartDashboard.putNumber("Encoder Distance" ,Robot.sensors.getDistance());
Here are the definitions for those methods in our sensor subclass:
public double getRate() {
    	return canEncoder.getRate();
    public double getDistance() {
    	return canEncoder.getDistance();
    public double getRaw() {
    	return canEncoder.getRaw();
And here is where we define our Talon and Encoder:
// BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
        motorsCANTalon = new CANTalon(0);
        LiveWindow.addActuator("Motors", "CAN Talon", motorsCANTalon);
        sensorscanEncoder = new Encoder(0, 1, false, EncodingType.k4X);
        LiveWindow.addSensor("Sensors", "canEncoder", sensorscanEncoder);
        sensorscanEncoder.setDistancePerPulse(1.0);
        sensorscanEncoder.setPIDSourceType(PIDSourceType.kRate);
    // END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=CONSTRUCTORS
        motorsCANTalon.reverseSensor(true);
        motorsCANTalon.setFeedbackDevice(FeedbackDevice.QuadEncoder);
        motorsCANTalon.configEncoderCodesPerRev(360);
        motorsCANTalon.setPosition(0);
        motorsCANTalon.setForwardSoftLimit(15.0);
        motorsCANTalon.setReverseSoftLimit(-15);
Is there something we are doing wrong? Anything we need to initialize so that we'll get values off the breakout?
Unread 16-01-2016, 14:55
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: Encoder Issues
Hey feoniks4505,
The Encoder class is for encoders wired to the roboRIO...
I think motorsCANTalon.getPosition() and motorsCANTalon.getSpeed() are what you want. Remember the sensor data comes from the Talon, to the RIO, which is where your code runs.
Checkout section 5.3 in the Talon SRX Software reference manual to see all the getters.
And when you are ready to use the internal closed-loop features of the Talon, check out the examples in section 12.
Also for the future, if anyone has a doubt of wiring-issue-versus-software-issue, use the self-test feature (Section 2.4) to see what the Talon sees for sensor data. Then you can rule out wiring versus software. Self-test works even if there is no-code.
