Go to Post ...we are all winners when people come out of this program and strive to make the world a better place. - Patrick Wang [more]
Unread 14-01-2016, 20:02
pensono pensono is offline
FRC #5495
pensono is an unknown quantity at this point
2016 Java roboRIO image
How would I load the 2016 Java image onto the roboRIO?
I am using the same roboRIO as last year when we used C++. I get the following error when trying to deploy a demo project.
BUILD FAILED
C:\Users\shsrobotics\wpilib\java\current\ant\build.xml:220: Assertion failed boolean test.
roboRIO Image does not match plugin, allowed image version: 19
Unread 14-01-2016, 20:38
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: 2016 Java roboRIO image
Thats not Java thats just the rio flash...
see here https://wpilib.screenstepslive.com/s...borio-firmware
Unread 14-01-2016, 21:23
And the one after about roboRIO image! And then the one after that about the JRE.
Unread 15-01-2016, 02:25
FRC #5495
Thanks, what's the current version of the flash?
Unread 15-01-2016, 07:59
Hey look, there's a document for that too! https://wpilib.screenstepslive.com/s...ware-revisions
Unread 15-01-2016, 21:11
Team5119Dmitri Team5119Dmitri is offline
FRC #5119
Team5119Dmitri is an unknown quantity at this point
We are also having this issue, but when we try to image the roboRIO the only version that shows up is version 23. Where can we get version 19?
Unread 15-01-2016, 21:21
Make sure you've installed the 2016 FRC Update Suite and you are in the LabVIEW 2015 folder.
Unread 18-01-2016, 15:16
zeldathegood zeldathegood is offline
FRC #4277
zeldathegood is an unknown quantity at this point
We seem to have only got the 2015 image? Where is a link to the 2016 roboRio image? I don't have a Labview 2015 folder? We downloaded only 2016 stuff but only can find the 2015 stuff
Unread 18-01-2016, 19:48
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
Hi -
I was having the same problem (and had verified multiple times that all the versions matched for install on roboRIO, and I had the 2016 FRC update to NI, and I had been in LabVIEW 2015 and was using the v19 image, etc.
It turns out that the fix is in a earlier posting ... where the previous year's built "wpilib" hadn't been deleted when I thought I had deleted everything in order to do a fresh install of the tools for 2016 (including a new version of Eclipse and Java). If you do this:
If that's the case, for some reason the plugins must be failing to update the files. Close Eclipse, delete your C:\Users\USERNAME\wpilib directory (where USERNAME is your username), then open Eclipse again.
that worked for me.
I am going to submit a document change request against the WPI documentation to include this on the troubleshooting page about "Image Check Failure", as following the steps there don't work.
It would be nice if the implementation of the plug-in worked correctly though.
Good luck!
Unread 18-01-2016, 20:04
AKA: Stu
And to answer the original question(s):
If you look on page 80 in the "Getting Started with the 2016 Control System", it will have a table of software and firmware numbers. The last two are for the RoboRIO firmware and the RoboRIO Image. If you have gotten those updated correctly following the instructions, the web browser admin page should show those version numbers on it (along with everything else).
To check that you have the right Java installed, ssh to your roboRIO and run the following: /usr/local/frc/JRE/bin/java -version and it should come back with what you picked from the Oracle site (probably 1.8.0_06).
WPILib just released a new version with the Update 2 package, and if you have this installed correctly, and go to (in Eclipse) Help -> About and then Select Installation Details. You should see the WPILib Java (or C++, I suppose) at 0.1.0.201601151923.
If all that lines up, and you are still getting the 23 error - deleting the built "wpilib" folder while Eclipse is closed, re-starting Eclipse and rebuilding the project to recreate it should work - at least it did for me.
