Go to Post Robotics is better than Football. Robotics > Football !!! - Arkorobotics [more]
Unread 15-01-2016, 20:19
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Team Update 2 (2016)
https://firstfrc.blob.core.windows.n...Updates/02.pdf
Unread 15-01-2016, 21:29
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Team Update 2 (2016)
Really disappointed they didn't fix G18 for climbing. This task is going to be very hard.
Looks like getting off a couple extra shots and challenging may be the way to go.
Unread 15-01-2016, 21:51
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
If it were easy it wouldn't be worth triple the points, right?
We've been trying to come up with ideas that allow for shorter robots that will have a low potential of violating this rule. It is challenging.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 15-01-2016, 22:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm confused about the complaint of extreme difficulty. Ri3D 1.0 looks like they've built a legal mechanism, or one that could very easily be made legal with a bit of frame extension on the front. It doesn't seem all that complicated for a tall robot, really. Now is it complicated for a short robot? Yes. But I suspect the GDC wanted to encourage a bit of innovation and effort beyond just copying tape measures from 2010.
Unread 15-01-2016, 22:32
Jarren Harkema's Avatar
Jarren Harkema Jarren Harkema is offline
Dancing Drive Coach
FRC #4967 (That ONE Team)
Jarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to allJarren Harkema is a name known to all
The updates to G25 and G40-1 Really nerfed some of the innovative strategy ideas. I guess they really want us to play this game as it was intended.
My question regarding G28 is this: If you can't contact an opponent in your courtyard, regardless of who initiates contact, how does G11 apply? It seems that G28 takes precedence, which means an opposing robot can cause the other alliance to foul without recourse.
Unread 15-01-2016, 22:40
EricH EricH is online now
If they aren't even trying to hang, then I think I could make a pretty good case to call for G11. Or, to be even more obvious, if they're chasing you around trying to make contact, and G11 isn't called, it might be time to have a chat with the Head Referee.
Unread 15-01-2016, 22:42
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
RE: updates to G25 and G40, I think the last time anyone played chicken with the GDC and won was 469 in 2010. These rule changes were coming.
RE: G28, I assume that is the case, but that is something that a Q&A could help codify. They don't want a robot blocking a challenge or scale, they want that robot challenging/scaling. Very 2011-esque rule, but that's probably how it works.
EDIT: Eric has a better handle on it... if that kind oif action he mentioned is repeated, it probably even ventures into a T6. The GDC doesn't want robots intentionally ignoring the opportunity to challenge by either screening up robots in the courtyard or chasing each other in the box.
Unread 15-01-2016, 22:43
The G11 blue box seems to make that pretty clear. It's a G28 penalty unless the team that would benefit from the G28 is clearly only trying to draw a penalty and not try to, say, CHALLENGE or SCALE or score a boulder.
Unread 15-01-2016, 22:58
Dancing Drive Coach
Good points all, thanks for clarifying. Wil and Kevin, I probably should have thrown a bit of sarcasm behind my statement, I figured these two areas were going to get fixed, it's just interesting to see how they resolved it.
Unread 15-01-2016, 23:00
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
I get that the GDC wants robots to play the game and challenge the tower themselves; however, I feel like it stifles late qualification round strategies of trying to limit your opponents getting additional ranking points and potentially overtaking you in the rankings. For example if your up on a team in the opposing alliance by 3 RP's. Your opponent is winning the game by more points than you could possibly score by trying to challenge yourself and their tower isn't weakened so no extra RP for you. It would make more since to try and deny your opponent the extra RP from capturing your tower rather than uselessly gaining game points for yourself.
Unread 16-01-2016, 00:30
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Can someone explain the update to G25 a bit better for me? Any extensions from outside the Secret Passage that can block multiple openings would be longer than 15" and blocking both openings from inside the Secret Passage puts you at a huge risk for a Technical Foul. I don't see how this new rule changes anything.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 16-01-2016, 01:14
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
There were discussion on having a robot stand outside the secret passage and block the openings in order to control the game (see discussion here).
There are still ways to make that concept work, but they just got a lot less likely to succeed.
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 16-01-2016, 07:41
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
How do you post a question to the Q&A? I created an account on Thursday, got the e-mail, verified, saw a web page that said I had full access, and logged in, but I can't find any place to ask a new question. Is the control hidden somewhere in plain sight?
  • The Q&A tab looks the same as before
  • The Team Questions tab says "Your request is in pending state"
  • The My Account tab says
    • Account Information (with info)
    • Change Password (with blocks for that)
    • User Settings (with two check boxes)
    • Questions I'm Following (with an empty table, as I have not followed any questions)
Unread 16-01-2016, 07:46
Originally Posted by GeeTwo View Post
How do you post a question to the Q&A? I created an account on Thursday...
You use the account info in TIMS, don't create one with your personal info. Personal accounts basically let you follow questions and that's about it.
Unread 16-01-2016, 08:11
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Thanks. I just thought they were anonymizing the names of those posting questions. Can any of the mentors/contacts associated with a team get this from TIMS, or just the primary and alternate? I don't see where the password would be.
